Ideal for professional use, ThinkVision T2454p LCD monitor offers high resolution and in plane switching panel which can maximize your viewing angle and visual experience. It also has multiple interface options and integrated USB 3.0 hub that makes your connectivity easier. Boasting low energy consumption and less environmental impact, T2454p meets green standards.
- Lenovo ThinkVision T2454p - LED monitor - 24"
- LED-backlit LCD monitor - 24"
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- 1920 x 1200 at 60 Hz
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 7 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 77.40%
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100/240 V (50/60 Hz)
- Raven black
- 55.74 cm x 26.42 cm x 40.25 cm
- 6.15 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV, RoHS, ISO 9241-307, WEEE, Green Mark, DDC-2B/CI, UL Environmental SPC Gold, CEL Grade 1
- 3-year warranty
- Display Type
- Diagonal Size
- 24"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- Pixel Pitch
- 0.27 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 77.40%
- Response Time
- 7 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- HDCP
- Raven black
- 55.74 cm x 26.42 cm x 40.25 cm - with stand
- 6.15 kg
- VGA , DisplayPort , HDMI , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x DisplayPort cable - 1.8 m , 1 x VGA cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1
- Dimensions & Weight Details
- Without stand - width: 55.74 cm - depth: 4.4 cm - height: 36.3 cm - weight: 4.22 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - replacement - 3 years - carry-in
- 0 °C
- 45 °C
- 10 - 80% (non-condensing)
