The Lenovo ThinkVision T23d-10 is a superior monitor that is meant to take your efficiency to new heights. With the vivid 22.5-inch display and versatile connectivity options, the ThinkVision T23d-10 lets you perform with your full potential.
The 16:10 aspect ratio of the T23d-10 monitor makes for an extra wide display and a superior viewing experience. The borderless panel of the bright WUXGA monitor and the super narrow bezel make it ideal for multi-screen connection, adding to your productivity. With up to 4ms response time, the anti-glare display minimizes motion blur and eliminates streaking and ghosting for a smooth interaction. The ThinkVision T23d-10 has a range of ports such as VGA, DP, and HDMI to boost productivity.
Increase Your Efficiency
The 22.5-inch borderless display offers 11% more space, allowing you to do much more. The extra thin bezel is beneficial especially if you are dealing with extensive data and need to work with multiple screens. -
Adaptable and Ergonomic
The ThinkVision T23d-10 is built to support you in any work environment. The wide 178° viewing angle eliminates disturbing reflections and makes for a brilliant and bright display, so you don't miss a single detail. Easy to assemble (tool-free), the ergonomic stand can lift, tilt, pivot, and swivel at your will. For a clutter-free desk, manage cables with the clip behind the stand. -
Clarity with Comfort
Promoting eye-safety, the ThinkVision T23d-10 comes with the TÜV Eye Comfort certification. It is the solution to long hours at the desk. Also, these monitors emit low blue light, which lessens eye-strain without hindering your productivity
- Lenovo ThinkVision T23d-10 - LED monitor - 22.5"
- LED-backlit LCD monitor - 22.5"
- Energy Class
- Class D
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200
- Pixel Pitch
- 0.25 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 50.12 cm x 25.19 cm x 49.19 cm
- 4.85 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, RoHS, ISO 9241-307, WEEE, DDC-2B/CI
- 3-year warranty
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 22.5"
- Panel Type
- IPS
- Aspect Ratio
- 16:10
- Native Resolution
- WUXGA 1920 x 1200
- Pixel Pitch
- 0.25 mm
- Pixel Per Inch
- 100.6
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Gamut
- 72%
- Response Time
- 6 ms
- Horizontal Viewing Angle
- +89 / -89
- Vertical Viewing Angle
- +89 / -89
- Backlight Technology
- WLED
- HDCP
- Black
- 4.85 kg
- VGA ¦ HDMI (HDCP) ¦ DisplayPort (HDCP)
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.8 m ¦ 1 x DisplayPort cable - 1.8 m ¦ Power cable
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
- 13.9 kWh/1000h
- Power Consumption (Typical)
- 15 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- OS Required
- Microsoft Windows 7 / 10
- Dimensions & Weight Details
- Width: 50.12 cm - depth: 25.19 cm - height: 49.19 cm - weight: 4.85 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years ¦ Limited warranty - backlight - 3 years
