Enjoy uncompromising performance with the ThinkVision T2324p LCD Monitor. This monitor offers FHD resolution and a professional In-plane Switching panel to maximise your viewing angle and visual experience. The T2324p also provides multiple interface options (VGA + HDMI + DP) and integrated USB3.0 hub, making it easy to connect. Boasting low energy consumption and less environmental impact, the T2324p adopts the latest green standards, meeting Energy Star 6.0, TUV Green Mark, EPEAT Gold, UL Environment Gold and more.
- Lenovo ThinkVision T2324p - LED monitor - Full HD (1080p) - 23"
- LED-backlit LCD monitor - 23"
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 7 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100/240 V / DC 12 V (50/60 Hz)
- 54.58 cm x 26.41 cm x 50.9184 cm
- 5.4 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, MPR II, TUV GS, VCCI, C-Tick, BSMI, cUL, GS, IEC950, NEMKO, NOM, SABS, SASO, TUV S, CCC, PSB, Lead-Free, SII, ISO 9241-307, KCC, WEEE, PSE Mark, JEITA, cTUVus, MEPS, TUV GM, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, CEL, UL Environmental SPC Gold, INSM, EAC, CEL Grade 1, China RoHS, ISC
- 3-year warranty
- Display Type
- Diagonal Size
- 23"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2652 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 7 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Video Bandwidth
- 205 MHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Colour Temperature
- 9300K, 7200K, 6500K
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, colour temperature
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
- 54.58 cm x 26.41 cm x 50.9184 cm - with stand
- 5.4 kg
- HDMI , DisplayPort , VGA , 4 x USB 3.0 downstream , USB 3.0 upstream , Audio line-out
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Localisation
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- Power Consumption (Typical)
- 21 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- OS Required
- Microsoft Windows 7, Windows 8, Windows 8.1
- Dimensions & Weight Details
- Without stand - height: 36.25 cm
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - replacement - 3 years - carry-in
- 0 °C
- 45 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
