Lenovo ThinkVision T2054p 19.5" 1440x900 VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: FGLXWS00 Mfr#: 60G1MAT2UK
The Lenovo ThinkVision monitor T2054p is a commercial monitor with premium product features. It contains built-in VGA + DP + HDMI interfaces and tilt stand function. It provides a wide viewing angle by IPS panel. To save space, this monitor is also designed to support ThinkCentre's Tiny PC with the Clamp Bracket. It is environmentally conscious, meeting the latest green standards including Energy Star 6.0 Certified, TUV Green Mark, EPEAT Gold Certified, TCO Display 6.0, TCO Certified Edge 2.0, UL Environment Gold, CEL 1, RoHs and 85% PCC plastic resins.
  • Adjustable comfort
    The Lenovo ThinkVision T2054p offers comprehensive display position adjustments including height, swivel, and tilt, ensuring optimal comfort and viewing experiences for extended use.
  • Vivid visuals
    Featuring a 16:10 image aspect ratio, 250 cd/m2 brightness, and a 1000:1 contrast ratio, this monitor delivers crisp, bright visuals and deep blacks for a superior viewing experience.
  • Efficient connectivity
    With HDMI, VGA, and DisplayPort inputs, the Lenovo ThinkVision T2054p provides versatile connectivity options, making it easy to connect to various devices without the need for multiple adapters.
  • Eco-friendly design
    ENERGY STAR certified, the Lenovo ThinkVision T2054p is designed with energy efficiency in mind, featuring a low power consumption of just 9.6 W in on mode, making it an environmentally friendly choice for your workspace.
Lenovo ThinkVision T2054p - LED monitor - 19.5"
LED-backlit LCD monitor - 19.5"
Energy Class
Class C
Power Consumption (On mode)
9.6 W
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900
Pixel Pitch
0.2915 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Colour Gamut
72%
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Height, swivel, tilt
Voltage
AC 100/240 V / DC 12 V (50/60 Hz)
Raven black
45.42 cm x 24.26 cm x 34.59 cm
3.7 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV, DDC/CI, RoHS, ISO 9241-307, WEEE, Green Mark, DDC-2B/CI, UL Environmental SPC Gold, CEL Grade 1, China RoHS, EDID compatible
3-year warranty
Display Type
Energy Class
Class C
Diagonal Size
19.5"
Panel Type
IPS
Aspect Ratio
16:10
Native Resolution
1440 x 900
Pixel Pitch
0.2915 mm
Pixel Per Inch
87
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Gamut
72%
Response Time
7 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP
Raven black
3.7 kg
VGA , DisplayPort (HDCP) , HDMI (HDCP)
Mechanical
Tilt Angle
-5/+22
Swivel Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), arsenic free
1 x VGA cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
9.6 W
9.6 kWh/1000h
Power Consumption (Typical)
14.5 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Microsoft Windows 7, Windows 8, Windows 8.1, Windows 10
Sustainability Information
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
45 °C
10 - 80%
