Lenovo ThinkVision Soundbar
Quicklinx: 6LW1WS00 Mfr#: 45K1264
The ThinkVision Soundbar allows you to add stereo sound to the selected without having to sacrifice valuable desk space. The stylish ThinkVision Soundbar is an excellent choice for adding stereo sound to Web broadcasts, multimedia presentations, and other applications that require audio.
Compatible with: L2440p Wide, L2440x Wide, L2251x Wide, L2251p Wide, L2250p Wide, L1951p Wide, L1900p, L1711p, L215p Wide, L215 Wide, and D185 Wide flat panel monitors. Attaches easily and securely to the bottom bezel of the Monitor An integrated cable lock slot allows you secure the soundbar to the monitor with an optional cable lock Dual Speakers provide a total of 6 watts of output Power and audio volume can be controlled directly from the soundbar Integrated Headphone and Microphone Jacks Stylish Lenovo ThinkVantage design Powered by external AC power adapter
  • Seamless integration
    Designed specifically for PC use, the Lenovo ThinkVision Soundbar offers a seamless audio experience. Its recommended placement under-the-monitor ensures it blends perfectly with your setup, providing clear sound without taking up valuable desk space.
  • Effortless power management
    With an external form factor and powered by an AC power adapter, this soundbar ensures your audio experience is uninterrupted. The convenience of the power adapter means you can easily manage your speaker's power source.
  • High-quality amplification
    The Lenovo ThinkVision Soundbar features an integrated amplifier within its active amplification type design. This setup ensures that your audio output is not only louder but also clearer, enhancing every multimedia experience on your PC.
Lenovo ThinkVision Soundbar - speakers - for PC
Speakers - for PC
Hong Kong, Malaysia, Singapore, Brunei, United Kingdom
Speaker Type
Active
Nominal Output Power (Total)
6 Watt
Amplifier
Integrated
34.5 cm x 6 cm x 5 cm
350 g
ThinkVision L1900p, L2440p, L2440x
Speakers - for PC
Speaker System
Speaker Type
Active
Audio System Continuous Power (Total)
6 Watt
Amplifier
Integrated
Recommended Placing
Under-the-monitor
Controls
Power on/off, volume
Connector Type
Headphones , Microphone , Audio line-in
Power adapter
Power adapter - external
Power Source
AC power adapter
34.5 cm
6 cm
5 cm
350 g
Lenovo ThinkVision L1900p, L2440p, L2440x
