The Lenovo ThinkVision S28u-10, sporting a 28-inch In-Plane Switching panel, offers professional monitor features while remaining a smart and intelligent business investment. The 4K UHD resolution screen has a 99% accurate sRGB color gamut and 90% accurate DCI-P3 color gamut, delivering pixel-perfect clarity that's ideal for multitasking, analytics, and graphic designing tasks. The NearEdgeless screen with wide viewing angles is aesthetic and effective in equal measure, enhancing collaboration capabilities. Equipped with both an HDMI 2.0 port and DisplayPort 1.2, the ThinkVision S28u-10 delivers flexible connectivity. For maximum user comfort, the natural low blue light emission minimizes eyestrain and enables an enjoyable viewing experience.
Eye-catching display
Experience superior visual output on the ThinkVision S28u-10 that has a 7.5% larger display area than 27-inch monitors of the same resolution. Crystal-clear visuals on the 4K UHD In-Plane Switching panel means no detail is too small. -
Comfortable user experience
Eyestrain is minimized thanks to the natural low blue light solution that reduces blue light emission without compromising color accuracy, brightness, or power efficiency. -
Enhanced connectivity
The monitor has HDMI 2.0 and a DisplayPort 1.2 that provide improved connectivity required for modern businesses.
- Lenovo ThinkVision S28u-10 - LED monitor - 4K - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class F
- Power Consumption (On mode)
- 26.4 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.1617 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 6 ms (typical)
- Colour Support
- 1.07 billion colours
- Colour Gamut
- 99% sRGB, 90% DCI-P3
- Input Connectors
- HDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 63.694 cm x 22.999 cm x 45.082 cm
- 5.24 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- CCC, RoHS, China Energy standard Tier 2, TUV Rheinland Eye Comfort Certification
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 28"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1617 mm
- Pixel Per Inch
- 157.35
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- NearEdgeless, 99% sRGB colour gamut
- Raven black
- 5.24 kg
- HDMI ¦ DisplayPort ¦ Audio line-out (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x HDMI cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 26.4 W
- Power Consumption SDR (On mode)
- 26.4 kWh/1000h
- Power Consumption (Typical)
- 28 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- OS Required
- Microsoft Windows 7, Windows 10
- Dimensions & Weight Details
- With stand - width: 63.694 cm - depth: 22.999 cm - height: 45.082 cm - weight: 5.24 kg ¦ Without stand - width: 63.694 cm - depth: 4.92 cm - height: 37.368 cm - weight: 4.58 kg
- Shipping Width
- 45.2 cm
- Shipping Depth
- 12.7 cm
- Shipping Height
- 72.3 cm
- Shipping Weight
- 7 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - 3 years
