Lenovo ThinkVision S27i-10 27" 1920x1080 6ms VGA HDMI IPS LED Monitor
Quicklinx: F5J6WS00 Mfr#: 61C7KAT1UK
Diagonal Size: 27in
Max Resolution: 1920 x 1080
Response Time: 6ms
Interfaces: HDMI, VGA (HD-15)
More than 50 in stock
£139.59 ex VAT
£167.50 inc VAT
The ThinkVision S27i-10 is a high-performance monitor specifically meant for your work in the office. With a 27-inch FHD In-Plane Switching display, enjoy a 178° wide viewing angle with crystal-clear detail and vivid colours. The excellent display performance and functions also optimise your working experience.
With the bezel width (side) being just 2.0 mm, the Near Edgeless FHD In-Plane Switching display offers an effective solution for a multi-display connection, enabling a seamless visual experience. The multiple ports include VGA and HDMI, which lets you expand your capabilities. Choose where you want your monitor; on a tilt-stand or on the wall. Eye Comfort certification by TÜV ensures these displays are easy on the eyes, allowing you to play much more.
Lenovo ThinkVision S27i-10 - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.311 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
6 ms (typical); 4 ms (extreme)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Raven black
61.19 cm x 22 cm x 44.35 cm
4.76 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 7, TCO Certified Edge Displays, ENERGY STAR Qualified
DDC/CI, RoHS, China Energy standard Tier 2, VESA TMDS, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Diagonal Size
27"
Viewable Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.311 mm
Pixel Per Inch
82
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
54 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Anti-glare, 72% colour gamut
Raven black
61.19 cm x 22 cm x 44.35 cm - with stand
4.76 kg
HDMI , VGA (HD-15) , Headphones
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
24 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand - width: 61.19 cm - depth: 22 cm - height: 44.35 cm - weight: 4.76 kg , Without stand - width: 61.19 cm - depth: 4.62 cm - height: 36.65 cm - weight: 4.22 kg
Shipping Width
71.5 cm
Shipping Depth
13.2 cm
Shipping Height
45.5 cm
Shipping Weight
6.8 kg
ENERGY STAR Certified
TCO Certified
Limited warranty - 3 years
10 - 80% (non-condensing)
Lenovo ThinkVision S27i-10 27 Bundle deal on Lenovo ThinkVision S27i-10 27" 1920x1080 6ms VGA HDMI IPS LED Monitor
£238.76
F5J6 Lenovo Microsaver Security Cable Lock In Stock £33.41
Diagonal Size: 27in
Response Time: 6ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Lenovo
Price Range Ex VAT: 100 - 150
