Uncompromised clarity and an amazing visual experience make the ThinkVision S24q a perfect monitor. This is best suited for small businesses looking for high-quality visuals, excellent performance, and user convenience. Its 23.8-inch In-Plane Switching (IPS), QHD display has wide viewing angles, making it ideal for business executives, graphic artists, and freelancers. The monitor is Low Blue Light certified, ensuring longer hours of productivity.
A monitor that delivers performance and value
Uncompromised clarity and an amazing visual experience make the ThinkVision S24q-10 a perfect monitor. This is best suited for small businesses looking for high-quality visuals, excellent performance, and user convenience. Its 23.8-inch In-Plane Switching (IPS), QHD display has wide viewing angles, making it ideal for business executives, graphic artists, and freelancers. The monitor is Low Blue Light certified, ensuring longer hours of productivity. -
Dynamic display
Business professionals can view and analyze complex data accurately, thanks to the 2560 x 1440 QHD monitor. Whether you're crunching numbers, or creating and editing design and videos, the 3-side NearEdgeless bezel gives you more screen real estate, improving work efficiency. Colors are sharp and bright with > 99% sRGB color gamut, providing impressive image quality -
Seamless connectivity
The ThinkVision S24q-10 monitor's HDMI and DisplayPort 1.2 ensure a seamless connection with your PC for easy multitasking. A high-quality integrated 3.5 mm audio out port facilitates better collaboration and easily connects to speakers or earphones. -
Enhanced user experience
Extended hours of screen time won't be taxing anymore - the ThinkVision S24q-10 is TÜV Eye Comfort certified for low blue light emission, flicker-free display, and reduced reflections, ensuring minimized eye fatigue. The quick-release tilt stand enables easy set-up and positioning of the ThinkVision S24q-10. With the unique cable management system, you can have an organized workspace with minimal clutter.
- Lenovo ThinkVision S24q-10 - LED monitor - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Class
- Class F
- Power Consumption (On mode)
- 19.7 W
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440 at 75 Hz
- Pixel Pitch
- 0.2058 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 6 ms, 4 ms (extreme), 14 ms (typical)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 53.98 cm x 20 cm x 40.27 cm
- 3.5 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Silver
- CCC, RoHS, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
- 3-year warranty
- Display Type
- Energy Class
- Class F
- Diagonal Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2058 mm
- Pixel Per Inch
- 123
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 48 - 75 Hz
- Horizontal Refresh Rate
- 30 - 114 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- NearEdgeless, 99% sRGB colour gamut
- Raven black
- 53.98 cm x 20 cm x 40.27 cm - with stand
- 3.5 kg
- DisplayPort 1.2 , HDMI , Audio line-out (mini-jack)
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), integrated cable management
- Cables Included
- 1 x HDMI cable
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 19.7 W
- Power Consumption SDR (On mode)
- 19.7 kWh/1000h
- Power Consumption (Typical)
- 20 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand - width: 53.98 cm - depth: 20 cm - height: 40.27 cm - weight: 3.5 kg , Without stand - width: 53.98 cm - depth: 4.2 cm - height: 32.57 cm
- Shipping Width
- 63.9 cm
- Shipping Depth
- 12.2 cm
- Shipping Height
- 40.5 cm
- Shipping Weight
- 5.1 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
