Lenovo ThinkVision S24i-30 24" 1920x1080 4ms VGA HDMI IPS LED Monitor
Quicklinx: J5DVWS00 Mfr#: 63DEKAT3UK
20 In Stock
£77.80 ex VAT
£93.36 inc VAT
The ThinkVision S24i-30 Monitor is easily the most practical choice to carry out daily office-related tasks. Its 23.8" In-Plane Switching screen displays rich delightful colors and clarity with Full-HD 1 920 x 1 080 resolution. A 99% sRGB color gamut offers you consistent colors and sharper images no matter the viewing angles. Its borderless design affords a distraction-free viewing experience both in a single and multi-system setup. Built-in Natural Low Blue Light technology filters out harmful blue light without affecting the picture quality to support extended screen time while reducing eye strain. A good selection of ports including HDMI, VGA, and audio out ensures easy connections with accessories so that you get all the tools you need for your work. Comfort is part of the package with the monitor's tilt functionality that allows you to adjust the screen to suit your posture. You can also VESA-mount it to suit your preferred viewing position. The monitor's stand features a built-in phone rack and cable management clips, to give you a clutter-free desktop and more space. A nifty joystick on the monitor enables you to easily navigate and change the display characteristics as per your preference. But best of all, the ThinkVision S24i-30 is in tune with the TCO 9.0 regulations and comes in green packaging, making it safe for the environment and you.
  • A treat for the eyes
    The ThinkVision S24i-30 Monitor's 23.8-inch 3-side NearEdgeless In-Plane Switching screen offers a distraction-free view. 1920 x 1080 resolution, 99% sRGB color gamut delivers superb clarity with consistent color and clarity across wide viewing angles. With built-in Natural Low Blue Light technology, the monitor filters out harmful blue light emissions to protect your eyes and reduce strain, without affecting the picture quality.
  • Hassle-free work set-up
    Easy to set up and manage, the ThinkVision S24i-30 Monitor will have you up and running in no time. A host of connectivity features including HDMI, VGA, and audio out ports help you plug in and connect easily to other devices and speakers or headphones. A VESA mount frees up your desktop and affords an optional viewing position. Thanks to a quick assemble and release button, the ThinkVision S24i-30 Monitor is designed to be easy to use.
  • Stylish and eco-friendly
    Great to look at, the ThinkVision S24i-30 Monitor's Storm Grey color and ultra-slim design is crafted to impress. More than just stylish, the ThinkVision S24i-30 Monitor is designed to care for you and the environment. It is compliant with TCO 9.0 regulation for sustainability and comes in green recyclable cushion packaging that benefits the environment.
Lenovo ThinkVision S24i-30 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1402682
Energy Class
Class E
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1300:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
Dimensions (WxDxH) - with stand (highest position)
53.94 cm x 18.3 cm x 43.4 cm
3.8 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
RoHS, VOC, TUV Rheinland Eye Comfort Certification, TUV Rheinland Low Blue Light (Hardware Solution), TUV Rheinland Eyesafe 2.0 Display
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
100 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Integrated cable management, 8-bit(6-bit + FRC) Colour Depth, 2 mm bezel (side), Natural Low Blue Light technology
Raven black
53.94 cm x 18.3 cm x 43.4 cm - with stand (highest position)
3.8 kg
HDMI , VGA , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Tiny support, Nano support
VESA mount
1 x HDMI cable - 1.8 m , 1 x power cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
13.5 Wh
Power Consumption (Max)
20.5 Wh
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10, Windows 11
Dimensions & Weight Details
With stand (lowest position) - width: 53.94 cm - depth: 18.3 cm - height: 43.4 cm - weight: 3.8 kg , With stand (highest position) - width: 53.94 cm - depth: 18.3 cm - height: 43.4 cm - weight: 3.8 kg , Without stand - width: 53.94 cm - depth: 43 cm - height: 32.62 cm - weight: 3 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
Brand: Lenovo
