The ThinkVision S24e-10 is a high-performance monitor specifically meant for your work in the office. With a 23.8-inch FHD VA panel, enjoy a 178° wide viewing angle with crystal-clear detail and vivid colours and high contrast ratio (3000). The excellent display performance and functions also optimise your working experience..
With the bezel width (side) being just 2.0 mm, the Near Edgeless FHD In-Plane Switching display offers an effective solution for a multi-display connection, enabling a seamless visual experience. The multiple ports include VGA and HDMI, which lets you expand your capabilities. Choose where you want your monitor; on a tilt-stand or on the wall. Low Blue Light certification by TÜV ensures these displays are easy on the eyes, allowing you to watch much more.
- Lenovo ThinkVision S24e-10 - LED monitor - Full HD (1080p) - 23.8"
- LED-backlit LCD monitor - 23.8"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/369887
- Energy Class
- Class D
- Power Consumption (On mode)
- 13.3 W
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.2745 mm
- Contrast Ratio
- 3000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 6 ms (typical)
- Input Connectors
- HDMI, VGA
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 53.95 cm x 20 cm x 40.27 cm
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 23.8"
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Contrast Ratio
- Response Time
- Vertical Refresh Rate
- 76 Hz
- Horizontal Refresh Rate
- 90 kHz
- Backlight Technology
- LED backlight
- Raven black
- VGA , HDMI
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- HDMI cable
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 13.3 W
- Power Consumption SDR (On mode)
- 13.3 kWh/1000h
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.0
- 0 °C
- 40 °C
- 10 - 80%
