Lenovo ThinkVision S24e 23.8" 1920x1080 6ms VGA HDMI LED Monitor
Quicklinx: FFVVWS00 Mfr#: 61CAKAT1UK
The ThinkVision S24e-10 is a high-performance monitor specifically meant for your work in the office. With a 23.8-inch FHD VA panel, enjoy a 178° wide viewing angle with crystal-clear detail and vivid colours and high contrast ratio (3000). The excellent display performance and functions also optimise your working experience..
With the bezel width (side) being just 2.0 mm, the Near Edgeless FHD In-Plane Switching display offers an effective solution for a multi-display connection, enabling a seamless visual experience. The multiple ports include VGA and HDMI, which lets you expand your capabilities. Choose where you want your monitor; on a tilt-stand or on the wall. Low Blue Light certification by TÜV ensures these displays are easy on the eyes, allowing you to watch much more.
Lenovo ThinkVision S24e-10 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/369887
Energy Class
Class D
Power Consumption (On mode)
13.3 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Contrast Ratio
3000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (typical)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
Raven black
53.95 cm x 20 cm x 40.27 cm
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class D
Diagonal Size
23.8"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Contrast Ratio
Response Time
Vertical Refresh Rate
76 Hz
Horizontal Refresh Rate
90 kHz
Backlight Technology
LED backlight
Raven black
VGA , HDMI
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
13.3 W
13.3 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
10 - 80%
