Lenovo ThinkVision S24e-20 24" 1920x1080 4ms VGA HDMI LED Monitor
Quicklinx: GVMSWS00 Mfr#: 62AEKAT2UK
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: None
Interfaces: HDMI, VGA (HD-15)
More than 50 In Stock
£118.64 ex VAT
£142.36 inc VAT
Equip your staff with a monitor that will help power their productivity. ThinkVision S24e-20 is an excellent performer that delivers core functionality with a sleek new form factor. Its 1920 x 1080 FHD resolution VA panel display produces vivid images to every one of your colleagues standing around the desk up to angles as extreme as 178°. The compact screen head is twice as slim as its previous generation and sits within a compact 3-side NearEdgeless frame. Place two side-by-side for a seamless visual setup without a big clumsy column breaking the scene. S24e-20 has your staff's individual comfort in mind. And tilting to the perfect angle, the modern and minimized square-based stand dials up comfort and stability while cutting down its physical footprint to give people more desk space to get the job done with clean efficiency. Then, it goes further, by incorporating a handy phone rack right inside that small square base, so that the phone is not just cleared off the desk, but it's angled perfectly for hands-free use. Cleaning up even more, the stand's built-in cable management system keeps wires out of sight and out mind. Which is a good thing because, with HDMI, VGA and Audio Out ports, S24e-20 can connect to a whole range of mission-critical devices such as PCs and even headphones. Of course, not every business scenario calls for a desk. So, with that in mind, you can mount this monitor on the wall through its 100 mm x 100 mm VESA mount capability, which will also hold a Lenovo Tiny or Nano PC discreetly behind the screen. And because your staff are your most precious asset, S24e-20 has TÜV Rheinland Eye Comfort Certified technology to protect them from eye fatigue.
  • Your 3-side NearEdgeless edge
    Make multitasking near-effortless with 3-side NearEdgeless display. Compare files side-by-side on two screens with an almost uninterrupted visual continuity. Share content with colleagues standing up, sitting down or far off to the side as much as 178°; everyone sees the same quality image thanks to a 23.8-inch, FHD 1920 x 1080 resolution, VA panel display. Its 7.1 mm slim head design has less than half the screen thickness of the model it replaces but will still hold a Lenovo Tiny or Nano PC tucked away on its back.
  • Visibly safe and comfortable
    S24e-20 has TÜV Eye Comfort certified technology to protect your employees' eyes even during long stretches of work. And for greater user comfort, the screen can tilt on its stand to the perfect angle to suit each individual user. Or simply take the monitor off the desk altogether and place onto the wall with its 100 x 100 mm VESA wall mount capability that can also hold a Tiny or Nano PC unseen behind the screen.
  • Connection, connection, connection
    Connect to your fleet of other devices thanks to extensive compatibility. Through HDMI 1.4, VGA and even Audio Out ports, S24e-20 works with PCs laptops and even headphones or external speakers. And you'll never be troubled by those devices' wires because the integrated cable management system tucks them tidily out of your way. And an extra touch that staff will appreciate is the new integrated phone holder right in the base of the stand.
Lenovo ThinkVision S24e-20 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
12.5 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
Raven black
54.04 cm x 17.31 cm x 43.45 cm
3.82 kg
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
CCC, RoHS, Directive 2002/95/EC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
93
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Integrated cable management, 3-side NearEdgeless
Raven black
54.04 cm x 17.31 cm x 43.45 cm - with stand
3.82 kg
HDMI , VGA (HD-15) , Audio line-out
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
12.5 W
12.5 kWh/1000h
Power Consumption (Typical)
17.5 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand - width: 54.04 cm - depth: 17.31 cm - height: 43.45 cm - weight: 3.82 kg , Without stand - width: 54.04 cm - depth: 4.55 cm - height: 32.72 cm - weight: 3.02 kg
Shipping Width
41.5 cm
Shipping Depth
12.4 cm
Shipping Height
62.4 cm
Shipping Weight
5.42 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Diagonal Size: 24in
Response Time: 4ms
Speakers: None
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Lenovo
