Equip your staff with a monitor that will help power their productivity. ThinkVision S24e-20 is an excellent performer that delivers core functionality with a sleek new form factor. Its 1920 x 1080 FHD resolution VA panel display produces vivid images to every one of your colleagues standing around the desk up to angles as extreme as 178°. The compact screen head is twice as slim as its previous generation and sits within a compact 3-side NearEdgeless frame. Place two side-by-side for a seamless visual setup without a big clumsy column breaking the scene. S24e-20 has your staff's individual comfort in mind. And tilting to the perfect angle, the modern and minimized square-based stand dials up comfort and stability while cutting down its physical footprint to give people more desk space to get the job done with clean efficiency. Then, it goes further, by incorporating a handy phone rack right inside that small square base, so that the phone is not just cleared off the desk, but it's angled perfectly for hands-free use. Cleaning up even more, the stand's built-in cable management system keeps wires out of sight and out mind. Which is a good thing because, with HDMI, VGA and Audio Out ports, S24e-20 can connect to a whole range of mission-critical devices such as PCs and even headphones. Of course, not every business scenario calls for a desk. So, with that in mind, you can mount this monitor on the wall through its 100 mm x 100 mm VESA mount capability, which will also hold a Lenovo Tiny or Nano PC discreetly behind the screen. And because your staff are your most precious asset, S24e-20 has TÜV Rheinland Eye Comfort Certified technology to protect them from eye fatigue.
Your 3-side NearEdgeless edge
Make multitasking near-effortless with 3-side NearEdgeless display. Compare files side-by-side on two screens with an almost uninterrupted visual continuity. Share content with colleagues standing up, sitting down or far off to the side as much as 178°; everyone sees the same quality image thanks to a 23.8-inch, FHD 1920 x 1080 resolution, VA panel display. Its 7.1 mm slim head design has less than half the screen thickness of the model it replaces but will still hold a Lenovo Tiny or Nano PC tucked away on its back. -
Visibly safe and comfortable
S24e-20 has TÜV Eye Comfort certified technology to protect your employees' eyes even during long stretches of work. And for greater user comfort, the screen can tilt on its stand to the perfect angle to suit each individual user. Or simply take the monitor off the desk altogether and place onto the wall with its 100 x 100 mm VESA wall mount capability that can also hold a Tiny or Nano PC unseen behind the screen. -
Connection, connection, connection
Connect to your fleet of other devices thanks to extensive compatibility. Through HDMI 1.4, VGA and even Audio Out ports, S24e-20 works with PCs laptops and even headphones or external speakers. And you'll never be troubled by those devices' wires because the integrated cable management system tucks them tidily out of your way. And an extra touch that staff will appreciate is the new integrated phone holder right in the base of the stand.
- Lenovo ThinkVision S24e-20 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class D
- Power Consumption (On mode)
- 12.5 W
- Adaptive-Sync Technology
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080
- Pixel Pitch
- 0.2745 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 3000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 6 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931)
- Input Connectors
- HDMI, VGA
- Tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 54.04 cm x 17.31 cm x 43.45 cm
- 3.82 kg
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
- CCC, RoHS, Directive 2002/95/EC, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
- Display Type
- Energy Class
- Class D
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- AMD FreeSync
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.2745 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Integrated cable management, 3-side NearEdgeless
- Raven black
- 54.04 cm x 17.31 cm x 43.45 cm - with stand
- 3.82 kg
- HDMI , VGA (HD-15) , Audio line-out
Mechanical
- Tilt
- Tilt Angle
- -5/+22
- VESA Mounting Interface
- 100 x 100 mm
- Security Slot Type
- Kensington security slot
- Input Voltage
- 12.5 W
- Power Consumption SDR (On mode)
- 12.5 kWh/1000h
- Power Consumption (Typical)
- 17.5 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
- Dimensions & Weight Details
- With stand - width: 54.04 cm - depth: 17.31 cm - height: 43.45 cm - weight: 3.82 kg , Without stand - width: 54.04 cm - depth: 4.55 cm - height: 32.72 cm - weight: 3.02 kg
- Shipping Width
- 41.5 cm
- Shipping Depth
- 12.4 cm
- Shipping Height
- 62.4 cm
- Shipping Weight
- 5.42 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
