Lenovo ThinkVision S22e 21.5" 1920x1080 4ms VGA HDMI LED Monitor
Quicklinx: FFVTWS00 Mfr#: 61C9KAT1UK
The 21.5" S22e-19 ThinkVision monitor with 178° wide viewing angle displays clearer images across the screen, and the flicker-free display reduces motion blur on fast-moving videos. Ideal for any kind of office environment, this monitor boosts productivity with versatile connectivity options, TÜV Low Blue Light certification, and a quick-release tilt stand for comfortable working modes.
  • Wide viewing angles
    With horizontal and vertical viewing angles of 178 degrees, the Lenovo ThinkVision S22e-19 offers a consistent and vibrant display from all perspectives, ensuring a high-quality viewing experience for multiple users or when viewing from different positions.
  • Optimized connectivity
    Featuring HDMI and VGA interfaces, this monitor provides versatile connectivity options, allowing for easy setup and integration with a wide range of devices.
  • Energy efficient
    Certified by ENERGY STAR, the Lenovo ThinkVision S22e-19 is designed to reduce energy consumption without compromising on performance, making it an eco-friendly choice for your computing needs.
  • Enhanced visual clarity
    The monitor boasts a dynamic contrast ratio of 3000000:1, Full HD resolution, and WLED backlight technology, delivering sharp, vivid images with deep blacks and bright whites.
  • Comfortable viewing experience
    Tilt adjustments ranging from -5 to +22 degrees, combined with TUV Rheinland Low Blue Light Certification, ensure a comfortable viewing experience, reducing eye strain during long usage periods.
Lenovo ThinkVision S22e-19 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/373102
Energy Class
Class D
Power Consumption (On mode)
11.5 W
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
Raven black
48.93 cm x 20 cm x 37.38 cm
2.75 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
CCC, EMC, FCC, DDC/CI, RoHS, WEEE, TUV Rheinland Low Blue Light Certification, China Energy standard Tier 2, VESA TMDS
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
21.5"
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72%
Response Time
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
54 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Anti-glare
Raven black
48.93 cm x 20 cm x 37.38 cm - with stand
2.75 kg
HDMI , VGA (HD-15) , Headphones
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
11.5 W
11.5 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand - width: 48.93 cm - depth: 20 cm - height: 37.83 cm - weight: 2.75 kg , Without stand - width: 48.93 cm - depth: 4.15 cm - height: 29.68 cm - weight: 2.46 kg
Shipping Width
58.2 cm
Shipping Depth
12 cm
Shipping Height
35 cm
Shipping Weight
4.07 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.0
Limited warranty - 3 years
10 - 80% (non-condensing)
