Lenovo ThinkVision S22e-20 21.5" 1920x1080 6ms VGA HDMI LED Monitor
Quicklinx: GJWZWS00 Mfr#: 62C6KAT1UK
Diagonal Size: 21.5in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: None
Interfaces: VGA (HD-15), HDMI
More than 50 In Stock
£101.50 ex VAT
£121.80 inc VAT
Express delivery Order within the next 17 hours for delivery tomorrow
ThinkVision S22e-20 gives users the fine detail they need while working out the small print on long contracts or inputting data for long periods. With 3-side NearEdgeless design, more of the monitor is dedicated to the screen with bulky bezels trimmed down to the minimum, allowing you to create a cleaner experience on your people's workstations. The monitor elevates its performance, as it sits higher on its stand. The stand also tilts to create even better angles conducive to each individual's work. Plus, with improved flexible cable management, it's much easier to tidy power cords off the desk and out of the way. And there's a bonus clutter-free feature here: Users will love the phone holder built into its stylish square base. Getting the right tools for staff also means managing their comfort and well-being. That's why S22e-20 cuts down harmful blue wavelengths that can lead to eye fatigue.
  • 3-side NearEdgeless viewing
    A 21.5-inch, 1920 x 1080 full HD display delivers crisp, vivid images to improve your staff's view of critical work. All the focus is on-screen thanks to 3-side NearEdgeless form factor that minimizes bezels. 2-monitor multitasking flows easily from one screen to the next with barely any interruption from the frame that holds each one. While the VA panel delivers the same quality image to any angle up to an impressive 178° in any direction, making viewing with colleagues even better than before.
  • Next-level user experience
    S22e-20 delivers vivid images in 72% NTSC color space at a brightness of 250 cd/m2. Performing better and looking smarter, its style overhaul brings a modern touch to any office with a slimmed-down design and minimal square-shaped foot that forms the stable base of its stand. Look closer and you'll see a phone holder carved cleverly into that stylish base to de-clutter each employee's phone from their workspace while also holding it at the perfect viewing angle. What you won't see are cables trailing over the desk because an enhanced, more flexible cable management system makes it easier to hold cords tight to the stand, well out of the way. S22e-20 stands taller than its predecessor and tilting, to allow greater comfort and versatility for each user.
  • Uncompromising comfort, convenience and connectivity
    Every aspect of the monitor has been revisited and reworked to deliver an elevated user experience that enhances productivity. To give your employees the best working conditions, S22e-20 uses TÜV Rheinland Low Blue Light certified technology that reduces the high-energy blue wavelengths that can cause eye strain. The result is a more comfortable viewing experience, even after long periods of crunching numbers. It also looks after your energy efficiency with its ENERGYSTAR 8.0 rating. As well as its ergonomic stand, the monitor can be placed on the wall for a completely clear workstation by using its 100 mm x 100 mm VESA wall mounting capability. And connecting to your fleet of computers and devices is instant and easy through HDMI 1.4 and VGA ports, as well as channeling sound out to headphones through Audio Out.
Lenovo ThinkVision S22e-20 - LED monitor - Full HD (1080p) - 21.5"
LED-backlit LCD monitor - 21.5"
Energy Class
Class E
Power Consumption (On mode)
16 W
Adaptive-Sync Technology
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
3000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
Raven black
48.93 cm x 17.31 cm x 40.51 cm
3.14 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Gold
RoHS, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification, China Energy standard Tier 2
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
21.5"
AMD FreeSync
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Anti-glare, 3-sided bezeless, 72% NTSC colour gamut
Raven black
48.93 cm x 17.31 cm x 40.51 cm - with stand
3.14 kg
HDMI , VGA (HD-15) , Headphones
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), integrated cable management
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
16 W
16 kWh/1000h
Power Consumption (Typical)
15 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7 / 10
Dimensions & Weight Details
With stand - width: 48.93 cm - depth: 17.31 cm - height: 40.51 cm - weight: 3.14 kg , Without stand - width: 48.93 cm - depth: 4.55 cm - height: 29.68 cm - weight: 2.39 kg
Shipping Width
58.7 cm
Shipping Depth
14 cm
Shipping Height
35.2 cm
Shipping Weight
4.68 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
Response Time: 6ms
Speakers: None
Interfaces: HDMI
Brand: Lenovo
Stock Status: Clearance
