The ThinkVision Pro2840m features a 4K display. With a3840x2160 panel, 10-bit colour, 270-nit brightness and 5-millisecond response time, the latest premium ThinkVision monitor is designed to offer an uncompromised display experience. With 157 pixels per inch and a three million to one dynamic contrast ratio, the stunning image is vibrant, sharp and detailed. The infinity glass design features touch-sensitive buttons and dual speakers. A full-function stand allows tilt, swivel and rotate, and includes DisplayPort, HDMI and multiple USB ports.ThinkVision Pro2840m is also respectful to the environment with numerous certifications including Energy Star 6.0, TCO certification, EPEAT Gold and many others.
- Lenovo ThinkVision Pro2840m - LED monitor - 4K - 28"
- LED-backlit LCD monitor - 28"
- Energy Class
- Class C
- Energy Consumption per Year
- 68.8 kWh
- Power Consumption (On mode)
- 47.1 W
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160 at 60 Hz
- Pixel Pitch
- 0.16 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms
- Input Connectors
- HDMI, DisplayPort, Mini DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- 66.59 cm x 28.93 cm x 44.325 cm
- 10.19 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, CSA, TUV, VCCI, C-Tick, BSMI, GOST, DDC-2B, IEC950, NEMKO, NOM, SABS, SASO, TUV S, VESA EDID, CB, CCC, IC, DDC/CI, RoHS, ISO 9241-307, KCC, WEEE, Green Mark, JEITA, cTUVus, MEPS, E-Standby, KC, Kvalitet, KUCAS, SONCAP, KEBS, CECP, DDC-2B/CI, UL Environmental SPC Gold, BELLIS, KONCAR, INSM, CEL Grade 1, CSM
- 3-year warranty
- Display Type
- Energy Class
- Class C
- 68.8 kWh
- Diagonal Size
- 28"
- Built-in Devices
- USB 2.0 hub
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.16 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 3000:1
- Response Time
- 5 ms
- Vertical Refresh Rate
- 25 - 70 Hz
- Video Bandwidth
- 594 MHz
- Horizontal Viewing Angle
- 170
- Vertical Viewing Angle
- 160
- Backlight Technology
- LED backlight
- HDCP
- 66.59 cm x 28.93 cm x 44.325 cm - with stand
- 10.19 kg
Audio
- Speakers
- HDMI , DisplayPort , Mini DisplayPort , USB 2.0 upstream , USB 2.0 downstream
Mechanical
- Tilt Angle
- -5/+25
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable - 1.8 m , 2 x USB cable - 1.8 m
- Localisation
- Power Supply
- Internal
- Input Voltage
- 47.1 W
- On / Off Switch
- OS Required
- Microsoft Windows 7 / Windows 8, Windows 8.1
- Dimensions & Weight Details
- With stand - width: 66.59 cm - depth: 28.93 cm - height: 44.325 cm - weight: 10.19 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - replacement - 3 years - carry-in
- 0 °C
- 40 °C
- 8 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
