Lenovo ThinkVision P32u 32" 3840x2160 HDMI DisplayPort Thunderbolt IPS LED Monitor
Quicklinx: FGN3WS00 Mfr#: 61C1RAT2UK
The Lenovo ThinkVision P32u-10 display makes your creative ideas come to life. It delivers lightning-fast, one-cable connection for power, data, video and audio. At the same time, you can truly boost productivity and enjoy a stunning visual experience by connecting dual monitors via Thunderbolt 3 out.
  • Versatile display options
    With height, pivot, swivel, and tilt adjustments, the Lenovo ThinkVision P32u-10 offers flexibility to suit any working style or office setup. Its ergonomic design ensures comfort during long working hours, making it a suitable choice for professionals.
  • Exceptional image quality
    The 32-inch LED-backlit LCD monitor delivers stunning visuals in 4K resolution, supported by a wide color gamut and precise pixel pitch of 0.1845 mm. The LED backlight enhances image clarity, making it perfect for graphic design, video editing, and any task requiring precise detail.
  • Comprehensive connectivity
    Equipped with multiple interfaces including 2xHDMI, DisplayPort, and Thunderbolt 3, the Lenovo ThinkVision P32u-10 ensures seamless connection to a wide range of devices. The built-in USB 3.0 hub further enhances its connectivity, offering easy access to plug in peripherals and devices.
Lenovo ThinkVision P32u-10 - LED monitor - 4K - 32"
LED-backlit LCD monitor - 32"
USB 3.0 hub
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 60 Hz
Pixel Pitch
0.1845 mm
Input Connectors
2xHDMI, DisplayPort, Thunderbolt 3
Display Position Adjustments
Voltage
Raven black
72.67 cm x 35 cm x 49.78 cm
10 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
DDC/CI, VESA TMDS
Display Type
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Vertical Refresh Rate
23 - 80 Hz
Horizontal Refresh Rate
30 - 160 kHz
Backlight Technology
LED backlight
Raven black
72.67 cm x 35 cm x 49.78 cm - with stand
10 kg
2 x HDMI , Thunderbolt 3 , DisplayPort , USB 3.0 upstream , 4 x USB 3.0 downstream , Audio line-out (mini-jack)
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
180
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
DDC/CI, VESA TMDS
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
57 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Microsoft Windows 7 / 10 (32/64 bits)
Dimensions & Weight Details
Without stand - width: 72.67 cm - depth: 6.33 cm - height: 43.15 cm - weight: 6.9 kg , With stand - width: 72.67 cm - depth: 35 cm - height: 49.78 cm - weight: 10 kg
Sustainability Information
ENERGY STAR Certified
35 °C
10 - 80% (non-condensing)
