The ThinkVision P27q monitor has a black glossy appearance with a full function ergonomic stand. It offers a crystal clear borderless IPS display of 2560x1440 resolution and sRGB 99% color gamut, providing vivid, accurate images from a wide viewing angle. Moreover, each monitor has been pre-calibrated to obtain an accurate and consistent color with a factory calibration report. With built-in power and the rich connectivity of 2HDMI, DP, mDP and DP out, P27q satisfies diverse connection demand and can make multi-screen easier with daisy chain. P27q also has 4 USB3.0 ports, including 1 with BC1.2, which offers quick charge to your USB devices. Its full function stand supports lift, tilt, pivot and swivel, which are all for your ease of use.
A Superior Display Where Colors Pop
Contemporarily designed, the ThinkVision P27q-20 accomplishes every task with clarity and precision, thanks to its QHD 2560 x 1440-pixel resolution display. A 27-inch screen is encased by 4-side NearEdgeless bezels for maximum screen real-estate. The 99% sRGB, 99% BT.709, and 85% DCI-P3 color ranges provide vibrant and engaging visuals, while factory color calibration (avg. Delta E<2) ensures color accuracy and consistency. -
Collaboration and Productivity Maximized
A perfect monitor for professionals who need flexibility and functionality, the ThinkVision P27q-20 is engineered to improve efficiency. Collaboration and multitasking on the ThinkVision P27q-20 are simple and effective with multi-screen compatibility, while an array of 5 USB ports (upstream and downstream) allow for easy connection to computers and peripherals. -
User-focused Functions
The ThinkVision P27q-20 offers adaptability to fit any desk with tilt, lift, pivot, and swivel functionality-including a higher lift range. The space-saving design, along with flexible cable management, and integrated phone holder means your deskspace remains uncluttered. TÜV Rheinland Eye Comfort certified low reflection, low blue light, and flicker-free technology assures minimal eye strain.
- Lenovo ThinkVision P27q-20 - LED monitor - 27"
- LED-backlit LCD monitor - 27"
- Energy Class
- Class E
- Power Consumption (On mode)
- 18.8 W
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 6 ms (normal)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 99% BT.709, 99% sRGB, 85% DCI-P3
- Input Connectors
- HDMI, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Raven black
- 61.38 cm x 20.8 cm x 44.15 cm
- 7.12 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
- CCC, RoHS, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.1 Gen 1 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- QHD 2560 x 1440
- Pixel Pitch
- 0.2331 mm
- Pixel Per Inch
- 109
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 60 Hz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Integrated cable management, Flicker Free technology, Low Blue Light technology, 4-side NearEdgeless, 99% sRGB colour gamut
- Raven black
- 61.38 cm x 20.8 cm x 44.15 cm - with stand
- 7.12 kg
- HDMI , DisplayPort , DisplayPort output , USB 3.1 Gen 1 upstream , 4 x USB 3.1 Gen 1 downstream , Headphones
Mechanical
- Tilt Angle
- -5/+35
- Swivel Angle
- 90
- Rotation Angle
- 180
- Height Adjustment
- 135 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x Mini DisplayPort-DisplayPort cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 18.8 W
- Power Consumption SDR (On mode)
- 18.8 kWh/1000h
- Power Consumption (Typical)
- 22 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- Dimensions & Weight Details
- With stand (lowest position) - width: 61.38 cm - depth: 20.8 cm - height: 44.15 cm - weight: 7.12 kg , With stand (highest position) - width: 61.38 cm - depth: 20.8 cm - height: 57.65 cm - weight: 7.12 kg , Without stand - width: 61.38 cm - depth: 4.69 cm - height: 35.38 cm - weight: 4.64 kg
- Shipping Width
- 72.2 cm
- Shipping Depth
- 18.2 cm
- Shipping Height
- 46.3 cm
- Shipping Weight
- 9.26 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Silver
- ENERGY STAR Certified
- ENERGY STAR Version
- 8.0
- Limited warranty - 3 years
Lenovo Thinkvision MC50 Monitor Webcam | In Stock | £51.40 |
