Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor
Quicklinx: FPV1WS00 Mfr#: 61E9GAT6UK
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Speakers: Speaker(s)
Interfaces: USB-C, HDMI, DisplayPort
Hurry, only 1 left in stock!
£347.97 ex VAT
£417.56 inc VAT
Smart functionality & attention to detail
Engineered for tech-savvy professionals who multitask, the ThinkVision P27h-20 monitor features a four sided near-edgeless, 27" QHD display that focuses on the details and accommodates multiscreen viewing. This space-saving device puts you in control with convenient, ergonomic tilt- and swivel-angles, as well as flexible cable management for a clutter-free workspace. Plus, the USB-C one-cable solution enables connection to a range of device types, and the Smart Power function delivers unhindered performance and improved efficiency. A plethora of features including integrated speakers & an Ethernet port.
Say hello to exquisite details
With the large-screen 27" ThinkVision P27h monitor, you’ll be amazed at what you can see. The 4-sided near-edgeless display features a QHD (2560 x 1440) high resolution panel. Plus you’ll enjoy wide-angle viewing of up to 178 degrees with in-plane switching (IPS). But what’s even more spectacular is the factory calibration and the sRGB color gamut, which ensures the best color accuracy and consistency while providing impressive image quality.
One cable, Smart Power
The ThinkVision P27h monitor’s USB-C one-cable solution ensures a seamless delivery of power across a range of options, boosting your productivity: integrated ethernet port, audio out, power charging, video, and USB data. The DP Out port enables a simple daisy-chain connection for multiple monitor setup—perfect for crunching numbers, editing content, or working with lines of code. The Smart Power function intelligently detects overall power consumption and dynamically manages the delivery—up to 90W to compatible USB-C devices—so you can save power and money. Additionally, built-in cable management and integrated speakers further reduce desktop clutter.
Comfort & convenience
The vertical stand with swivel, tilt, pivot, and increased lift (max 135mm / 5.31") functionality ensures easy positioning of the monitor and reduces strain on your neck and back. With the flexible cable management system, wires don’t get entangled minimizing clutter. An integrated phone holder, VESA mount, minimized square base also let you have an organized desk. The P27h is TÜV Eye Comfort-certified to minimize eye fatigue, ensuring you work exertion free.
  • Say hello to exquisite details
    With the large-screen 27" ThinkVision P27h monitor, you'll be amazed at what you can see. The 4-sided near-edgeless display features a QHD (2560 x 1440) high resolution panel. Plus you'll enjoy wide-angle viewing of up to 178 degrees with in-plane switching (IPS). But what's even more spectacular is the factory calibration and the sRGB color gamut, which ensures the best color accuracy and consistency while providing impressive image quality.
  • One cable, smart power
    The ThinkVision P27h monitor's USB-C one-cable solution ensures a seamless delivery of power across a range of options, boosting your productivity: integrated Ethernet port, audio out, power charging, video, and USB data. The DP Out port enables a simple daisy-chain connection for multiple monitor setup - perfect for crunching numbers, editing content, or working with lines of code. The Smart Power function intelligently detects overall power consumption and dynamically manages the delivery - up to 90W to compatible USB-C devices - so you can save power and money. Additionally, built-in cable management and integrated speakers further reduce desktop clutter.
  • Comfort & convenience
    The vertical stand with swivel, tilt, pivot, and increased lift (max 135mm / 5.31") functionality ensures easy positioning of the monitor and reduces strain on your neck and back. With the flexible cable management system, wires don't get entangled minimizing clutter. An integrated phone holder, VESA mount, minimized square base also let you have an organized desk. The P27h is Eye Comfort-certified to minimize eye fatigue, ensuring you work exertion free.
Lenovo ThinkVision P27h-20 - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class F
Power Consumption (On mode)
23.5 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Brightness
350 cd/m²
Input Connectors
HDMI, DisplayPort, USB-C
Display Position Adjustments
Screen Coating
Anti-glare
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays
TUV Rheinland Eye Comfort Certification
Display Type
Energy Class
Class F
Diagonal Size
27"
Viewable Size
27"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
WQHD 2560 x 1440
Brightness
350 cd/m²
Vertical Refresh Rate
60 Hz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
99% sRGB colour gamut, integrated cable management, 85% DCI-P3, 99% BT.709 colour gamut, 4-side NearEdgeless, integrated phone holder
Audio
Speakers - stereo
HDMI , DisplayPort , DisplayPort output , USB-C 3.1 Gen 1 , USB 3.1 Gen 1 downstream with Battery Charging , 3 x USB-C 3.1 Gen 1 , Network
Mechanical
Tilt Angle
-5/+35
Swivel Angle
90
Rotation Angle
90
Height Adjustment
135 mm
VESA Mounting Interface
100 x 100 mm
1 x USB-C to USB-C cable - 1.8 m
Security Slot Type
Kensington security slot
23.5 W
23.5 kWh/1000h
TCO Certified
Diagonal Size: 27in
Interfaces: USB-C
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Lenovo
Stock Status: In stock
