Lenovo Thinkvision MC50 Monitor Webcam
Quicklinx: GRWXWS00 Mfr#: 4XC1D66056
Compatibility: PC
Interface: USB
More than 50 In Stock
£36.56 ex VAT
£43.87 inc VAT
Add clarity to your business vision with Lenovo ThinkVision MC50 Monitor Webcam. This feature-rich webcam adds easy functionality to your daily operations when paired with compatible monitors. Capturing 1080p RGB video images with its 1/2.9-inch RGB sensor, MC50 delivers clear images for all your videoconferencing needs. Its wide 90° field of view fits your content comfortably in the frame, while the cam swivels -45° to 225° and tilts +/-30° up and down. Thanks to Lenovo's proprietary smart traffic light, which automatically turns on a tiny light when you are engaged in a meeting, and a physical camera shutter, you can say goodbye to privacy concerns. MC50's built-in dual microphones with noise cancellation provide clear audio that you can count on, captured up to 2 meters away.
Lenovo ThinkVision MC50 - webcam
Webcam
Audio
Yes: built-in two microphones
126 g
Raven black
Wired
Camera
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Optical Sensor Type
RGB - 1/2.9"
USB 2.0
Privacy shutter
3-year warranty
Environmental Parameters (operating)
-5 °C - 40 °C; 0 - 90% relative humidity
Webcam
Audio Support
Wired
126 g
Camera
Digital Video Format
MJPEG, YUY2
Max Digital Video Resolution
1920 x 1080
Digital Video Capture Resolution
1280 x 720, 1920 x 1080, 640 x 480
Frame Rate (max)
Privacy shutter
Image Sensor
RGB 1/2.9"
Total Pixels
2800000 x 2800000
Computer Interface
USB 2.0
FCC, ICES, CB 62368-1, KCC, BSMI, VCCI, SASO, EAC, NOM
Raven black
Microsoft Windows 7, Windows 10, Windows 10 Home in S mode, Windows 10 Pro, Windows 10 Home Single Language 64-bit Edition
Limited warranty - replacement - 3 years
Shipping Width
15 cm
Shipping Depth
12.6 cm
Shipping Height
5.8 cm
Shipping Weight
237 g
-5 °C
Relative Humidity (operating)
0 - 90%
Compatibility: PC
Interface: USB
Brand: Lenovo
