Add clarity to your business vision with Lenovo ThinkVision MC50 Monitor Webcam. This feature-rich webcam adds easy functionality to your daily operations when paired with compatible monitors. Capturing 1080p RGB video images with its 1/2.9-inch RGB sensor, MC50 delivers clear images for all your videoconferencing needs. Its wide 90° field of view fits your content comfortably in the frame, while the cam swivels -45° to 225° and tilts +/-30° up and down. Thanks to Lenovo's proprietary smart traffic light, which automatically turns on a tiny light when you are engaged in a meeting, and a physical camera shutter, you can say goodbye to privacy concerns. MC50's built-in dual microphones with noise cancellation provide clear audio that you can count on, captured up to 2 meters away.
 - Lenovo ThinkVision MC50 - webcam
 - Webcam
- Audio
 - Yes: built-in two microphones
 - 126 g
 - Raven black
- Connectivity Technology
 - Wired
- Camera
- Max Resolution
 - 1920 x 1080
- Frame Rate (max)
 - 30 frames per second
- Optical Sensor Type
 - RGB - 1/2.9"
 - USB 2.0
 - Privacy shutter
 - 3-year warranty
- Environmental Parameters (operating)
 - -5 °C - 40 °C; 0 - 90% relative humidity
 - Webcam
- Audio Support
 - Wired
 - 126 g
Camera
- Digital Video Format
 - MJPEG, YUY2
- Max Digital Video Resolution
 - 1920 x 1080
- Digital Video Capture Resolution
 - 1280 x 720, 1920 x 1080, 640 x 480
- Frame Rate (max)
 - Privacy shutter
Image Sensor
 - RGB 1/2.9"
- Total Pixels
 - 2800000 x 2800000
- Computer Interface
 - USB 2.0
 - FCC, ICES, CB 62368-1, KCC, BSMI, VCCI, SASO, EAC, NOM
 - Raven black
- OS Required
 - Microsoft Windows 7, Windows 10, Windows 10 Home in S mode, Windows 10 Pro, Windows 10 Home Single Language 64-bit Edition
 - Limited warranty - replacement - 3 years
- Shipping Width
 - 15 cm
- Shipping Depth
 - 12.6 cm
- Shipping Height
 - 5.8 cm
- Shipping Weight
 - 237 g
 - -5 °C
 - 40 °C
- Relative Humidity (operating)
 - 0 - 90%
