Add clarity to your business vision with Lenovo ThinkVision MC50 Monitor Webcam. This feature-rich webcam adds easy functionality to your daily operations when paired with compatible monitors. Capturing 1080p RGB video images with its 1/2.9-inch RGB sensor, MC50 delivers clear images for all your videoconferencing needs. Its wide 90° field of view fits your content comfortably in the frame, while the cam swivels -45° to 225° and tilts +/-30° up and down. Thanks to Lenovo's proprietary smart traffic light, which automatically turns on a tiny light when you are engaged in a meeting, and a physical camera shutter, you can say goodbye to privacy concerns. MC50's built-in dual microphones with noise cancellation provide clear audio that you can count on, captured up to 2 meters away.
- Lenovo ThinkVision M50 - webcam
- Webcam
- Audio
- Yes: built-in two microphones
- 126 g
- Raven black
- Connectivity Technology
- Wired
- Camera
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- RGB - 1/2.9"
- USB 2.0
- Privacy shutter
- 3-year warranty
- Environmental Parameters (operating)
- -5 °C - 40 °C; 0 - 90% relative humidity
- Webcam
- Audio Support
- Wired
- 126 g
Camera
- Digital Video Format
- MJPEG, YUY2
- Max Digital Video Resolution
- 1920 x 1080
- Digital Video Capture Resolution
- 1280 x 720, 640 x 480, 1920 x 1080
- Frame Rate (max)
- Privacy shutter
Image Sensor
- RGB 1/2.9"
- Total Pixels
- 2800000 x 2800000
- Computer Interface
- USB 2.0
- VCCI, BSMI, NOM, SASO, FCC, KCC, ICES, EAC, CB 62368-1
- Raven black
- OS Required
- Microsoft Windows 7, Windows 10, Windows 10 Pro, Windows 10 Home Single Language 64-bit Edition, Windows 10 Home in S mode
- Limited warranty - replacement - 3 years
- Shipping Width
- 15 cm
- Shipping Depth
- 12.6 cm
- Shipping Height
- 5.8 cm
- Shipping Weight
- 237 g
- -5 °C
- 40 °C
- Relative Humidity (operating)
- 0 - 90%
