Lenovo ThinkVision M14t 14" 1920x1080 6ms USB-C Touchscreen LED Monitor
Quicklinx: GG7YWS00 Mfr#: 62A3UAT1WL
Diagonal Size: 14in
Max Resolution: 1920 x 1080
Response Time: 6ms
Speakers: None
Interfaces: USB-C
£307.09 ex VAT
£368.50 inc VAT
Built for mobile professionals who are adapting to a new era of flexible working, the M14t becomes the perfect companion for users who need to vary their workplaces. The crisp and accurate visuals with 300 nit brightness capability and impressive viewing angles make it ideal for presentations or managing multiple content windows across two displays. The tilt function and height adjustment ensure the most comfortable viewing position and Low Blue Light technology lets users work with minimal eye strain.
The active digital pen that supports 4096 levels of pressure offers unmatched precision when it comes to drawing, sketching, and collaborating. Switching the view from annotating a presentation in landscape mode to digitally sign a document or contract in portrait mode is made very simple thanks to auto-rotation sensors that do not require additional software or driver installation. Additionally, an intuitive on-screen display menu enables easy access to brightness, contrast, and rotation settings.
  • SEE MORE EVERYWHERE YOU GO
    Built for mobile professionals, the M14t's 14" Full-HD IPS panel display with super-narrow bezels ensures crisp and accurate visuals with impressive viewing angles, making it ideal for presentations. This sleek ultra-portable monitor with tilt function (-5°/ 90°) and a height-adjustable stand (up to 11 mm) allows users to work in a flexible and comfortable viewing position in any work environment. Get a clear view of the display, whether you are outdoors or in an office, with 300 nits brightness capability. Moreover, the TÜV Rheinland Low Blue Light technology lets you work with minimal eyestrain.
  • DELIVER AS ONLY YOU CAN
    Drag, draw, annotate, and collaborate, no matter where you are. The ThinkVision M14t is 10-point touch-enabled for an intuitive interactive experience even on the go, allowing you to create with a personal touch. It comes along with an active digital pen that supports 4096 levels of pressure, so you can draw and sketch with unmatched precision. Switch your view in no time with auto-rotation sensors that don't require software or driver installation. Additionally, an intuitive on-screen-display (OSD) menu enables easy access to brightness, contrast, and rotation settings.
  • CONNECT BETTER, WORK EASIER
    Built with an innovative dual USB-C design, the M14t can duplicate or extend your screen-be it your smartphone or laptop-so you're always productive. With data, power, and media capabilities of USB-C, you can create a presentation, transfer data to a hard drive, and enjoy the unique power pass-through function. With dual USB-C port, the power pass-through function supplies power to the M14t and the compatible USB-C device connected to the monitor simultaneously via one AC/DC adapter. Enjoy the option of a vertical display setup and better cable management for a clean, easy desktop setup with the L-shaped dongle.
Lenovo ThinkVision M14t - LED monitor - Full HD (1080p) - 14"
LED-backlit LCD monitor - 14" - touchscreen
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/363233
Energy Class
Class C
Energy Consumption per Year
25.5 kWh
Digital pen USB PD 65 watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Brightness
300 cd/m²
Contrast Ratio
700:1 / 3000000:1 (dynamic)
Response Time
8 ms (typical), 6 ms (extreme)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC
Input Connectors
2xUSB-C
Display Position Adjustments
Height, pivot (rotation), tilt
Voltage
AC 100-240 V (50/60 Hz)
Raven black
Dimensions (WxDxH) - with stand (highest position)
32.34 cm x 1.4 cm x 22.65 cm
698 g
Environmental Standards
ENERGY STAR Qualified EPEAT Silver
CCC, RoHS, TUV Rheinland Low Blue Light Certification, China Energy standard Tier 2, EU RoHS 2002/95/EC, TÜV Rheinland Low Blue Light
3-year warranty
ThinkPad X1 Yoga Gen 8 21HQ
Display Type
Energy Class
Class C
25.5 kWh
Diagonal Size
14"
USB Power Delivery
65 watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Pixel Per Inch
157
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Integrated cable management, Low Blue Light Mode, Wide Viewing Angle, 4096 degress of pressure sensitivity, 8-bit(6-bit + FRC) Colour Depth, active pen support, 5.43 mm bezel (side)
Raven black
32.34 cm x 1.4 cm x 22.65 cm - with stand (highest position)
698 g
Input
Digital pen - touchscreen
2 x USB-C 3.2 Gen 1/DisplayPort 1.2 Alt Mode (power up to 65W)
Mechanical
Tilt Angle
-5/+90
Rotation Angle
180
Height Adjustment
11 mm
VESA Mounting Interface
100 mm
Security lock slot (cable lock sold separately), 2 mounting holes
Digital pen
1 x USB-C to USB-C cable , 1 x USB-C to USB-C adapter - L-shape
Security Slot Type
Kensington security slot
Input Voltage
7 kWh/1000h
Power Consumption (Typical)
8 watt
Power Consumption (Max)
9.5 watt
Power Consumption Sleep
0.3 watt
Power Consumption (Off Mode)
0.3 watt
On / Off Switch
Included Software
Lenovo ThinkColour
Microsoft Windows 7, Windows 10, Windows 11
Dimensions & Weight Details
With stand (highest position) - width: 32.34 cm - depth: 1.4 cm - height: 22.65 cm - weight: 698 g , With stand (lowest position) - width: 32.34 cm - depth: 1.4 cm - height: 21.43 cm - weight: 698 g
Shipping Width
26.7 cm
Shipping Depth
37.7 cm
Shipping Height
6.8 cm
Shipping Weight
1.87 kg
Sustainability Information
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
ENERGY STAR Version
8.0
Limited warranty - 3 years
10 - 80%
Lenovo ThinkPad X1 Yoga Gen 8 21HQ
Diagonal Size: 14in
Response Time: 6ms
Speakers: None
Interfaces: USB-C
Brand: Lenovo
