Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor
Quicklinx: FGLVWS00 Mfr#: 61DDUAT6UK
The ThinkVision M14 is an ultraslim and ultralight mobile monitor. Its 14-inch screen helps you extend your workspace comfortably no matter where work takes you.
Compatible with notebooks of any screen size that come with a USB Type-C port which supports DP1.2 Alt mode and PD2.0, the ThinkVision M14 can either extend or duplicate your notebook display with one plug.
The innovative USB Type-C ports on each side of the monitor along with its ambidextrous design that allows both left- and right-handed users to work easily, and an ergonomic design enhances user experience. Packed with impressive portability, connectivity, and flexibility features, the ThinkVision M14 is ideal for mobile productivity.
  • ACHIEVE TARGETS ON THE GO
    The ThinkVision M14 boosts productivity with its thin and light form factor. Weighing 598 g, this 4.4 mm sleek mobile monitor enables easy portability. The stylish design with a Full-HD, IPS display provides vivid lifelike visuals, ensuring you never miss out on any detail. With a brightness of 300 nits, the ThinkVision M14 offers a stunning visual experience while consuming content online.
  • EXPERIENCE ADVANCED CONNECTIVITY
    Two innovative USB Type-C ports on either side of the monitor make connectivity effortless. These ports support both power and video delivery simultaneously from a single port. The ThinkVision M14 also offers a'power pass through' design that powers the mobile monitor by an adapter and charges the notebook at the same time. This feature is suitable for smartphones or notebooks with one USB Type-C port. The ambidextrous design of this monitor enhances user comfort.
  • WORK THE WAY YOU LIKE
    The ThinkVision M14 with its admirable flexibility is built for varied job roles. With a tilt angle of-5°~90°, you can position your monitor in a way that suits your style. Compare content with ease even as you use laptops of different screen sizes with the ergonomic height adjustable foot. Also, you can wall mount your monitor effortlessly with mounting support for a hands-free viewing experience. The advanced low blue light technology minimizes eye strain, making extended working hours easy.
Lenovo ThinkVision M14 - LED monitor - Full HD (1080p) - 14"
LED-backlit LCD monitor - 14"
Energy Class
Class B
Energy Consumption per Year
15.53 kWh
Power Consumption (On mode)
4.88 W
USB PD 65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Brightness
300 cd/m²
Contrast Ratio
700:1 / 3000000:1 (dynamic)
Response Time
6 ms
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
2xUSB-C
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare
Voltage
Raven black
32.337 cm x 9.654 cm x 20.903 cm
0.57 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
CCC, RoHS, ISO 9241-307, Directive 2002/95/EC, China Energy standard Tier 2
3-year warranty
Display Type
Energy Class
Class B
15.53 kWh
Diagonal Size
14"
USB Power Delivery
65 Watt
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1611 mm
Pixel Per Inch
157
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
6 ms
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Low Blue Light Mode, Mercury free, arsenic-free glass, Eye comfort mode, Eye-Care Technology, 8-bit + A-FRC Colour Depth
Raven black
32.337 cm x 9.654 cm x 20.903 cm - with stand
0.57 kg
2 x USB-C 3.1 Gen 1/DisplayPort Alt Mode with Power Delivery 2.0 (power up to 65W)
Mechanical
Height, tilt
Tilt Angle
-5/+90
VESA Mounting Interface
100 x 100 mm
Clips
1 x USB-C cable - 1 m
Security Slot Type
Kensington security slot
Input Voltage
4.88 W
5.4 kWh/1000h
Power Consumption (Typical)
6 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
On / Off Switch
Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
With stand (highest position) - width: 32.337 cm - depth: 9.654 cm - height: 22.003 cm - weight: 570 g , With stand (lowest position) - width: 32.337 cm - depth: 9.654 cm - height: 20.903 cm - weight: 570 g
Shipping Width
40.2 cm
Shipping Depth
27.6 cm
Shipping Height
6.1 cm
Shipping Weight
1.67 kg
Sustainability Information
ENERGY STAR Certified
ENERGY STAR Version
7.1
Limited warranty - 3 years
30 - 80%
