Lenovo ThinkVision LT3053p 30" 2560x1600 6ms VGA DP HDMI LED Monitor
Quicklinx: 8XKGWS00 Mfr#: 60A4RAT1UK
For professionals demanding a monitor with workstation grade front-of-screen performance and cutting edge productivity features, ThinkVision proudly introduces its state of the art LT3053p 30-inch Professional Monitor. LT3053p sports a gorgeous 30-inch AH-IPS panel that provides users with a clear and crisp display at 2560 x 1600 resolution from different angles. Moreover, it delivers a color depth of 1.07 billion colors and an Adobe RGB color gamut of 99% which ensure both color consistency and accuracy. On top of its amazing display, it boasts additional productivity features that provide a distinct user experience; its ThinkVision PIP Anywhere solution and keyboard & mouse one switch toggle allow users to simultaneously work between two PC systems seamlessly and effectively. ThinkVision LT3053p also comes bundled with a professional shading hood and supports optional color calibrators to further enhance the user's viewing experience. To top it all, ThinkVision LT3053p is designed without compromising sustainability by adopting the latest green standards; it's certified Energy Star 6.0, TUV Green Mark, EPEAT Gold, TCO Display 6.0, TCO Certified Edge 1.2, and UL Environment Gold. For high performance computing, ThinkVision LT3053p Professional Monitor is simply the best choice for you.
Lenovo ThinkVision LT3053p - LED monitor - 30"
LED-backlit LCD monitor - 30"
Energy Class
Class C
Energy Consumption per Year
91 kWh
Power Consumption (On mode)
63 W
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
2560 x 1600 at 60 Hz
Pixel Pitch
0.2505 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
1.07 billion colours
Colour Gamut
99% Adobe RGB
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Display Position Adjustments
Voltage
Business black
69 cm x 24.15 cm x 47.11 cm
11.5 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
FCC Class B certified, VESA DPMS, VESA FPMPMI, RoHS, ISO 9241-307, China Energy Label Level 1, TUV GM, DDC-2B/CI, UL Environmental SPC Gold
3-year warranty
Display Type
Energy Class
Class C
91 kWh
Diagonal Size
30"
Built-in Devices
USB 3.0 hub
Panel Type
AH-IPS
Aspect Ratio
16:10
Native Resolution
Pixel Pitch
0.2505 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% Adobe RGB
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Controls & Adjustments
Brightness, contrast, H/V position, input select
OSD Languages
Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
Mobile High-Definition Link (MHL)
Business black
69 cm x 24.15 cm x 47.11 cm - with stand
11.5 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
HDMI , DisplayPort , DVI-D (dual link) , VGA (DB-15) , 3 x USB 3.0 downstream , 2 x USB 2.0 downstream
Mechanical
Tilt Angle
35
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Detachable hood
1 x VGA cable - 1.8 m , 1 x DisplayPort cable - 1.8 m , 1 x DVI cable - 1.8 m , 1 x SuperSpeed USB cable - 1.8 m , 1 x USB cable - 1.8 m
Mounting Kit
Optional
Power Supply
Internal
Input Voltage
63 W
Power Consumption (Typical)
88 Watt
Power Consumption Stand by
1.2 Watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 69 cm - depth: 24.15 cm - height: 47.11 cm - weight: 11.5 kg , Without stand - width: 69 cm - depth: 6.2 cm - height: 44.93 cm
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
10 - 80%
8XKG C2G HDMI to VGA Adapter Converter Dongle - Video converter - Black In Stock £14.57
