For mainstream professionals who demand better productivity, collaboration and manageability, Lenovo presents ThinkVision LT2223z VoIP monitor from its ThinkVision VoIP series. Packed with an integrated FHD webcam, two digital microphones and speakers, LT2223z makes collaboration over the internet simpler and more convenient; and with a built-in USB Hub, it provides better manageability and just an overall distinct user experience. It's designed without compromises, featuring a 21.5-inch FHD LED backlit panel, an array of connectivity options, and also Tiny PC support. To top it all, it meets the latest standards of green certifications, qualified by Energy Star 6.0, TUV Green Mark, EPEAT Gold, TCO Display 6.0, TCO Certified Edge 1.1, and UL Environment Gold.
- Lenovo ThinkVision LT2223z - LED monitor - Full HD (1080p) - 21.5"
- LED-backlit LCD monitor - 21.5"
- Energy Class
- Class A
- Energy Consumption per Year
- 25.1 kWh
- Power Consumption (On mode)
- 17.2 W
- USB 3.0 hub, FHD camera
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 2000000:1 (dynamic)
- Response Time
- 5 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- HDMI, VGA, DisplayPort
- Speakers
- Internal
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Business black
- 51.26 cm x 21.84 cm x 37.94 cm
- 5.43 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified EPEAT Gold
- MPR II, TUV GS, VCCI, BSMI, GOST, GS, IEC950, NEMKO, NOM, SABS, SASO, TUV S, VESA DPMS, CCC, IC, PSB, RoHS, ISO 9241-307, Green Mark, JEITA, cTUVus, E-Standby, KC, Kvalitet, EPA, DDC-2B/CI, INSM
- 3-year warranty
- Display Type
- Energy Class
- Class A
- 25.1 kWh
- Diagonal Size
- 21.5"
- Built-in Devices
- Panel Type
- TN
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 5 ms
- Vertical Refresh Rate
- 50 - 75 Hz
- Horizontal Viewing Angle
- +85 / -85
- Vertical Viewing Angle
- +80 / -80
- Backlight Technology
- WLED
- Controls & Adjustments
- Brightness, contrast, H/V position, input select, VoIP
- OSD Languages
- Chinese (simplified), English, German, French, Italian, Russian, Spanish, Japanese
- HDCP
- Business black
- 51.26 cm x 21.84 cm x 37.94 cm - with stand
- 5.43 kg
Audio
- Speakers - stereo - internal
- Output Power / Channel
- 3 Watt
- HDMI , DisplayPort , VGA (DB-15) , USB 3.0 upstream , 2 x USB 3.0 downstream
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Stand
- Cables Included
- 1 x USB cable - 1.8 m , 1 x VGA cable - 1.8 m
- Mounting Kit
- Optional
- Localisation
- Power Supply
- Internal
- Input Voltage
- 17.2 W
- Power Consumption (Typical)
- 24 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- Display drivers
- Dimensions & Weight Details
- With stand - width: 51.26 cm - depth: 21.84 cm - height: 37.94 cm - weight: 5.43 kg , Without stand - width: 51.26 cm - depth: 5.64 cm - height: 35.11 cm - weight: 3.53 kg
Sustainability Information
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
