Lenovo Thinkvision LT1913p 19" 1280x1024 VGA DVI LED Monitor
Quicklinx: CWWKWS00 Mfr#: 60FBHAT1UK
ThinkVision LT1913p 19-inch Square In-plane Switching LED Backlit LCD Monitor.
The Lenovo ThinkVision monitor LT1913p is a commercial monitor with premium product features which suits users using traditional legendary square display formats best. With built-in VGA + DVI interfaces, it offers users outstanding HD picture quality. It displays an absolutely clear picture quality with its In-plane Switching panel, which is soothing for the human eye after long viewing in office working environments and has extensive wide-angle views. It contains full ergonomic features with its full-function stand, offering tilt, lift, pivot and swivel functions. The LT1913p monitor coordinates with any Lenovo ThinkCentre systems and matches the Lenovo design thanks to its black finish. It delivers the best value on investment for large enterprises. It is environmentally conscious, meeting the latest green standards including Energy Star 6.0 Certified, TUV Green Mark, EPEAT Gold Certified, TCO Display 6.0, TCO Certified Edge 1.1, UL Environment Gold, CEL 1, RoHs and 85% PCC plastic resins. To save space, this monitor is also designed to support ThinkCentre's Tiny PC with the Clamp Bracket.
Lenovo ThinkVision LT1913p - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class E
Power Consumption (On mode)
12.6 W
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 76 Hz
Pixel Pitch
0.0976 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
7 ms
Colour Support
16.7 million colours
Colour Gamut
72%
Input Connectors
DVI-D, VGA
Display Position Adjustments
Voltage
Business black
41.1 cm x 22.19 cm x 37.83 cm
4.55 kg
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
FCC Class B certified, TUV, VCCI, BSMI, GOST, GS, NEMKO, NOM, SASO, TUV S, VESA EDID, CCC, IC, PSB, RoHS, ISO 9241-307, KCC, WEEE, Green Mark, JEITA, cTUVus, REACH, E-Standby, KC, Kvalitet, CECP, DDC-2B/CI, EPA 6.0, CEL Grade 1, China RoHS, IEC60950/EN60950, VOC, CU
3-year warranty
Display Type
Energy Class
Class E
Diagonal Size
19"
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.0976 mm
Pixel Per Inch
86.8
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72%
Response Time
7 ms
Vertical Refresh Rate
60 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
OSD Languages
English, German, French, Italian, Russian, Spanish, Japanese, Chinese
HDCP
Business black
4.55 kg
DVI-D (HDCP) , VGA
Mechanical
Tilt Angle
-5/+30
Swivel Angle
90
Rotation Angle
90
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
Input Voltage
12.6 W
12.6 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Sustainability Information
ENERGY STAR Certified
Limited warranty - replacement - 3 years - carry-in
10 - 80%
