ThinkVision LT1913p 19-inch Square In-plane Switching LED Backlit LCD Monitor.
The Lenovo ThinkVision monitor LT1913p is a commercial monitor with premium product features which suits users using traditional legendary square display formats best. With built-in VGA + DVI interfaces, it offers users outstanding HD picture quality. It displays an absolutely clear picture quality with its In-plane Switching panel, which is soothing for the human eye after long viewing in office working environments and has extensive wide-angle views. It contains full ergonomic features with its full-function stand, offering tilt, lift, pivot and swivel functions. The LT1913p monitor coordinates with any Lenovo ThinkCentre systems and matches the Lenovo design thanks to its black finish. It delivers the best value on investment for large enterprises. It is environmentally conscious, meeting the latest green standards including Energy Star 6.0 Certified, TUV Green Mark, EPEAT Gold Certified, TCO Display 6.0, TCO Certified Edge 1.1, UL Environment Gold, CEL 1, RoHs and 85% PCC plastic resins. To save space, this monitor is also designed to support ThinkCentre's Tiny PC with the Clamp Bracket.
Adjustable comfort
The Lenovo ThinkVision LT1913p offers comprehensive display position adjustments including height, swivel, and tilt, ensuring optimal comfort and ergonomics for extended use. -
Exceptional clarity
Featuring a 19-inch IPS display with a 1280 x 1024 native resolution, the LT1913p delivers crisp, clear images with a 178-degree viewing angle, making it perfect for professional environments. -
Energy efficient
Certified by ENERGY STAR, the LT1913p is designed for efficiency with a power consumption of only 12.6 W in on mode, making it an eco-friendly choice for your workspace.
- Lenovo ThinkVision LT1913p - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/371735
- Energy Class
- Class E
- Power Consumption (On mode)
- 12.6 W
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 76 Hz
- Pixel Pitch
- 0.0976 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 7 ms
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72%
- Input Connectors
- DVI-D, VGA
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Business black
- 41.1 cm x 22.19 cm x 37.83 cm
- 4.55 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- FCC Class B certified, TUV, VCCI, BSMI, GOST, GS, NEMKO, NOM, SASO, TUV S, VESA EDID, CCC, IC, PSB, RoHS, ISO 9241-307, KCC, WEEE, Green Mark, JEITA, cTUVus, REACH, E-Standby, KC, Kvalitet, CECP, DDC-2B/CI, EPA 6.0, CEL Grade 1, China RoHS, IEC60950/EN60950, VOC, CU
- 3-year warranty
- Display Type
- Energy Class
- Class E
- Diagonal Size
- 19"
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.0976 mm
- Pixel Per Inch
- 86.8
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Colour Gamut
- 72%
- Response Time
- 7 ms
- Vertical Refresh Rate
- 60 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- OSD Languages
- English, German, French, Italian, Russian, Spanish, Japanese, Chinese
- HDCP
- Business black
- 4.55 kg
- DVI-D (HDCP) , VGA
Mechanical
- Tilt Angle
- -5/+30
- Swivel Angle
- 90
- Rotation Angle
- 90
- Height Adjustment
- 110 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x VGA cable - 1.8 m , 1 x DVI cable - 1.8 m
- Localisation
- Input Voltage
- 12.6 W
- Power Consumption SDR (On mode)
- 12.6 kWh/1000h
- Power Consumption (Typical)
- 24 watt
- Power Consumption Stand by
- 0.5 watt
- Power Consumption Sleep
- 0.5 watt
- 0.5 watt
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - replacement - 3 years - carry-in
- 0 °C
- 40 °C
- 10 - 80%
