Lenovo ThinkVision E24q-30 24" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor
Quicklinx: J05GWS00 Mfr#: 63ECGAT2UK
48 In Stock
£117.14 ex VAT
£140.56 inc VAT
23.8-inch QHD (2560 x 1440) resolution IPS display that offers 1.77 times more pixels than FHD.
3-sided NearEdgeless bezel design helps you focus on your work with fewer distractions.
Vivid and smooth image quality with 99% sRGB, 100Hz refresh rate and 1300:1 CR.
TÜV Rheinland Eye Comfort certification lets you do more by protecting your eyes from fatigue.
Adjust the monitor for a more comfortable viewing experience with the ergonomic stand (tilt, lift, swivel, and pivot).
Efficient working with DP 1.2, HDMI 1.4.
Clear sound with built-in speakers (2W x 2).
Promote sustainability by following the latest environmental regulations (TCO9.0, EPEAT).
  • Uncompromised Features for Your Daily Work
    23.8" QHD (2560x1440) monitor provides 1.77 times greater resolution than FHD displays. 3-sided borderless display looks stylish and keeps your attention on task. Enjoy wide-viewing angles (H/V 178/178) with the IPS (In-Plane Switching) panel. Experience vivid images with 99% sRGB, stutter-free video enhanced by a 100Hz refresh rate, and sharper contrasts with a 1300:1 contrast ratio.
  • Better View from Any Angle
    Wide viewing IPS screen brings best view from any angle.
  • Clear Screen with Color Accuracy
    23.8" 2560 x 1440 QHD clarity; 99% sRGB color
  • Comfortable& Eye-Caring
    Natural Low Blue Light display without affecting color performance Lenovo Natural Low Blue Light Mode VS Conventional Blue Filter Mode
  • Minimized Border
    3-side NearEdgeless screen maximizes your vision, good for multi-tasking
  • HDMI+DP+VGA
    A range of connectivity options from VGA and HDMI 1.4 ports to DP 1.2 ports ensure you're always ready to plug in and perform.
  • Built-In Speakers
    Built-in speakers provide seamless audio experience without the need for additional equipment.
  • Sustainable Development
    This monitor has been made with sustainable materials including 85% recycled plastics with post-consumer plastic. And it is packed with sustainable paper pulp that is good for the environment. The monitor also meets the latest environmental standards.
Lenovo ThinkVision E24q-30 - LED monitor - QHD - 24"
LED-backlit LCD monitor - 24"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 100 Hz
Pixel Pitch
0.206 mm
Brightness
300 cd/m²
Contrast Ratio
1300:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 14 ms (Off), 6 ms (typical)
Colour Support
16.7 million colours
Colour Gamut
99% sRGB
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
Dimensions (WxDxH) - with stand (lowest position)
53.94 cm x 17.86 cm x 34.22 cm
4.7 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
RoHS 2011/65/EU, TUV Rheinland Low Blue Light Certification, EU Energy Label, TUV Rheinland Flicker Free Certification, TUV Rheinland Eye Comfort Certification, China Energy standard Tier 1, TUV Rheinland Low Blue Light (Hardware Solution)
3-year warranty
Display Type
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.206 mm
Pixel Per Inch
123
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
99% sRGB
Response Time
Vertical Refresh Rate
48 - 100 Hz
Horizontal Refresh Rate
30 - 155 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Integrated cable management, 3-side NearEdgeless, 8-bit(6-bit + FRC) Colour Depth, Natural Low Blue Light technology, 1.8 mm bezel (side)
Raven black
53.94 cm x 17.86 cm x 34.22 cm - with stand (lowest position)
4.7 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
HDMI , DisplayPort 1.2
Mechanical
Tilt Angle
-5/+22
Swivel Angle
360
Rotation Angle
180
Height Adjustment
155 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), Tiny support
1 x HDMI cable - 1.8 m , 1 x power cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
16 Watt
Power Consumption (Max)
38.5 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10, Windows 11
Dimensions & Weight Details
With stand (lowest position) - width: 53.94 cm - depth: 17.86 cm - height: 34.22 cm - weight: 4.7 kg , With stand (highest position) - width: 53.94 cm - depth: 17.86 cm - height: 49.72 cm - weight: 4.7 kg , Without stand - width: 53.94 cm - depth: 4.6 cm - height: 32.2 cm - weight: 3.2 kg
Shipping Width
62.1 cm
Shipping Depth
12.6 cm
Shipping Height
38.5 cm
Shipping Weight
6.7 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
Limited warranty - 3 years
8 - 80% (non-condensing)
Brand: Lenovo
