                Built-In SpeakersThe ThinkVision E24-30 monitor comes with built-in speakers, offering a fantastic audio experience without the need for additional equipment. This design helps you save desk space and reduce cable clutter, providing a sleek and efficient setup for a more enjoyable and streamlined experience.
                Natural Low Blue LightThe ThinkVision E24-30 monitors are equipped with Natural Low Blue Light technology, which is TUV-certified to protect your eyes, while the Hardware Solution effectively reduces blue light without causing any color distortion.
                Sustainable DevelopmentOur recyclable paper/pulp cushion packaging uses 85% post-consumer content (PCC), which helps lower CO2 emissions.
- Lenovo ThinkVision E24-30 - LED monitor - Full HD (1080p) - 24"
- LED-backlit LCD monitor - 24"
- Energy Class
- Class C
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 100 Hz
- Pixel Pitch
- 0.275 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1300:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms (extreme), 14 ms (Off), 6 ms (normal)
- Colour Support
- 16.7 million colours (6-bit+FRC)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 100-240 V (50/60 Hz)
- Raven black
- Dimensions (WxDxH) - with stand (lowest position)
- 53.94 cm x 17.86 cm x 34.22 cm
- 4.7 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
- RoHS 2011/65/EU, TUV Rheinland Low Blue Light Certification, VOC, TUV Rheinland Flicker Free Certification, TUV Rheinland Eye Comfort Certification, TUV Rheinland Low Blue Light (Hardware Solution), TUV Rheinland Eyesafe 2.0 Display
- 3-year warranty
- Display Type
- Energy Class
- Class C
- Diagonal Size
- 24"
- Viewable Size
- 23.8"
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.275 mm
- Pixel Per Inch
- 93
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 48 - 100 Hz
- Horizontal Refresh Rate
- 30 - 115 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Integrated cable management, 3-side NearEdgeless, Natural Low Blue Light technology, 1.8 mm bezel (side)
- Raven black
- 53.94 cm x 17.86 cm x 34.22 cm - with stand (lowest position)
- 4.7 kg
Audio
- Speakers
- Output Power / Channel
- 2 Watt
- HDMI , DisplayPort 1.2 , VGA
Mechanical
- Tilt Angle
- -5/+22
- Swivel Angle
- 360
- Rotation Angle
- 180
- Height Adjustment
- 155 mm
- VESA Mounting Interface
- 100 x 100 mm
- Cables Included
- 1 x HDMI cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 12 Watt
- Power Consumption (Max)
- 29 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.3 Watt
- OS Required
- Windows 10, Windows 11
- Dimensions & Weight Details
- With stand (lowest position) - width: 53.94 cm - depth: 17.86 cm - height: 34.22 cm - weight: 4.7 kg , With stand (highest position) - width: 53.94 cm - depth: 17.86 cm - height: 49.72 cm - weight: 4.7 kg , Without stand - width: 53.94 cm - depth: 4.6 cm - height: 32.2 cm - weight: 3.1 kg
- Shipping Width
- 62.1 cm
- Shipping Depth
- 12.6 cm
- Shipping Height
- 38.5 cm
- Shipping Weight
- 6.7 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
- EPEAT Gold
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 8 - 80% (non-condensing)
