Lenovo ThinkVision E24-28 24" 1920x1080 6ms VGA HDMI DisplayPort IPS LED Monitor
Quicklinx: GW6VWS00 Mfr#: 62B6MAT3UK
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: VGA (HD-15), HDMI, DisplayPort
£145.17 ex VAT
£174.20 inc VAT
New-generation employees demand monitors with a sharp resolution, picture clarity, and are comfortable to use. With its 23.8-inch display, 3-side NearEdgeless, and In-Plane Switching panel, the ThinkVision E24-28 is positioned as an everyday workhorse. An array of ports like HDMI, DP, and VGA offers versatile connectivity. Ergonomic design, with a broad lift, tilt, and pivot and swivel range of ± 360°, enhances user comfort and productivity, making it a smart choice for offices.
  • Consistent Visuals
    Full-HD resolution with an In-Plane Switching display delivers clear visuals even at different viewing angles. The 3-side NearEdgeless bezels allow users to set up a multi-screen workplace for efficient multitasking and collaboration. Moreover, TÜV Rheinland Eye Comfort certification ensures minimal eye strain and fatigue.
  • Seamless Interfacing
    Catering to the needs of the new-gen workforce, the ThinkVision E24-28 offers multiple connectivity options such as DP, VGA, and HDMI, enabling them to collaborate and engage with their peers efficiently. The built-in speakers on this monitor provide decent audio clarity, enhancing the productivity in meetings.
  • Crafted for Convenience
    Designed keeping its users in mind, the ThinkVision E24-28 provides a lift range of 155 mm, tilt angles of-5°/ 22°, swivel angles of ± 360°, and a pivot range of ± 90°, giving employees the option to customize the monitor any way they want, minimizing neck and back strains and aches. The 100 mm VESA mount support offers flexible mounting options to optimize the available workspace.
Lenovo ThinkVision E24-28 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Power Consumption (On mode)
14 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
Dimensions (WxDxH) - with stand (lowest position)
54.18 cm x 17.86 cm x 31.17 cm
4.8 kg
English / United Kingdom
Environmental Standards
TCO Certified Displays 8, TCO Certified Edge Displays, ENERGY STAR Qualified EPEAT Silver
CCC, RoHS, CEE Tier 1, RoHS 2011/65/EU, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification
3-year warranty
Display Type
Energy Class
Class D
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Colour Gamut
72% NTSC (CIE 1931)
Response Time
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
3-side NearEdgeless
Raven black
54.18 cm x 17.86 cm x 31.17 cm - with stand (lowest position)
4.8 kg
Audio
Speakers - stereo
Output Power / Channel
1.5 Watt
VGA , HDMI , DisplayPort 1.2
Mechanical
Tilt Angle
-5/+22
Swivel Angle
720
Rotation Angle
180
Height Adjustment
155 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable - 1.8 m
Security Slot Type
Kensington security slot
Input Voltage
14 W
14 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Sleep
0.5 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
With stand (lowest position) - width: 54.18 cm - depth: 17.86 cm - height: 31.17 cm - weight: 4.8 kg , With stand (highest position) - width: 54.18 cm - depth: 17.86 cm - height: 46.25 cm - weight: 4.8 kg , Without stand - width: 54.18 cm - depth: 4.17 cm - height: 32.64 cm - weight: 3.1 kg
Shipping Width
63.8 cm
Shipping Depth
14.5 cm
Shipping Height
39.7 cm
Shipping Weight
5.7 kg
Sustainability Information
TCO Certified
EPEAT Compliant
EPEAT Silver
ENERGY STAR Certified
Limited warranty - 3 years
Diagonal Size: 24in
Response Time: 4ms
Interfaces: HDMI
Interfaces: DisplayPort
Brand: Lenovo
