New-generation employees demand monitors with a sharp resolution, picture clarity, and are comfortable to use. With its 23.8-inch display, 3-side NearEdgeless, and In-Plane Switching panel, the ThinkVision E24-28 is positioned as an everyday workhorse. An array of ports like HDMI, DP, and VGA offers versatile connectivity. Ergonomic design, with a broad lift, tilt, and pivot and swivel range of ± 360°, enhances user comfort and productivity, making it a smart choice for offices.
Consistent Visuals
Full-HD resolution with an In-Plane Switching display delivers clear visuals even at different viewing angles. The 3-side NearEdgeless bezels allow users to set up a multi-screen workplace for efficient multitasking and collaboration. Moreover, TÜV Rheinland Eye Comfort certification ensures minimal eye strain and fatigue. -
Seamless Interfacing
Catering to the needs of the new-gen workforce, the ThinkVision E24-28 offers multiple connectivity options such as DP, VGA, and HDMI, enabling them to collaborate and engage with their peers efficiently. The built-in speakers on this monitor provide decent audio clarity, enhancing the productivity in meetings. -
Crafted for Convenience
Designed keeping its users in mind, the ThinkVision E24-28 provides a lift range of 155 mm, tilt angles of-5°/ 22°, swivel angles of ± 360°, and a pivot range of ± 90°, giving employees the option to customize the monitor any way they want, minimizing neck and back strains and aches. The 100 mm VESA mount support offers flexible mounting options to optimize the available workspace.
 - Lenovo ThinkVision E24-28 - LED monitor - Full HD (1080p) - 24"
 - LED-backlit LCD monitor - 24"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/400592
- Energy Class
 - Class D
- Power Consumption (On mode)
 - 14 W
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
 - Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
 - 0.2745 mm
- Brightness
 - 250 cd/m²
- Contrast Ratio
 - 1000:1 / 3000000:1 (dynamic)
- Response Time
 - 4 ms (extreme), 6 ms (normal)
- Colour Support
 - 16.7 million colours
- Colour Gamut
 - 72% NTSC (CIE 1931)
- Input Connectors
 - HDMI, VGA, DisplayPort
 - Height, pivot (rotation), swivel, tilt
- Screen Coating
 - Anti-glare
- Voltage
 - AC 100-240 V (50/60 Hz)
 - Raven black
- Dimensions (WxDxH) - with stand (lowest position)
 - 54.18 cm x 17.86 cm x 31.17 cm
 - 4.8 kg
- Localisation
 - English / United Kingdom
- Environmental Standards
 - TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Silver
 - CCC, RoHS, CEE Tier 1, RoHS 2011/65/EU, DisplayPort 1.2, TUV Rheinland Eye Comfort Certification
 - 3-year warranty
- Display Type
- Energy Class
 - Class D
- Diagonal Size
 - 24"
- Viewable Size
 - 23.8"
- Panel Type
 - IPS
- Aspect Ratio
 - 16:9
- Native Resolution
- Pixel Pitch
 - 0.2745 mm
- Pixel Per Inch
 - 92
- Brightness
 - 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
 - Anti-glare
- Backlight Technology
 - WLED
 - 3-side NearEdgeless
 - Raven black
 - 54.18 cm x 17.86 cm x 31.17 cm - with stand (lowest position)
 - 4.8 kg
Audio
 - Speakers - stereo
- Output Power / Channel
 - 1.5 Watt
 - VGA , HDMI , DisplayPort 1.2
Mechanical
- Tilt Angle
 - -5/+22
- Swivel Angle
 - 720
- Rotation Angle
 - 180
- Height Adjustment
 - 155 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Cables Included
 - 1 x HDMI cable - 1.8 m
- Localisation
- Security Slot Type
 - Kensington security slot
- Input Voltage
 - 14 W
- Power Consumption SDR (On mode)
 - 14 kWh/1000h
- Power Consumption (Typical)
 - 18 Watt
- Power Consumption Sleep
 - 0.5 Watt
 - 0.5 Watt
- Dimensions & Weight Details
 - With stand (lowest position) - width: 54.18 cm - depth: 17.86 cm - height: 31.17 cm - weight: 4.8 kg , With stand (highest position) - width: 54.18 cm - depth: 17.86 cm - height: 46.25 cm - weight: 4.8 kg , Without stand - width: 54.18 cm - depth: 4.17 cm - height: 32.64 cm - weight: 3.1 kg
- Shipping Width
 - 63.8 cm
- Shipping Depth
 - 14.5 cm
- Shipping Height
 - 39.7 cm
- Shipping Weight
 - 5.7 kg
Sustainability Information
- TCO Certified
- EPEAT Compliant
 - EPEAT Silver
- ENERGY STAR Certified
 - Limited warranty - 3 years
