Lenovo ThinkSystem PM1645a Mainstream SSD 800GB 2.5" SAS 12Gb/s
Quicklinx: G7R4WS00 Mfr#: 4XB7A17062
Form Factor: 2.5
Type: Solid state drive
Capacity: 800GB
£905.03 ex VAT
£1,086.03 inc VAT
The ThinkSystem PM1645a Mainstream SAS 12Gb solid-state drives (SSDs) are high-performance SSDs suitable for a wide range of applications of running on ThinkSystem servers. Unlike SATA drives, the 12 Gb/s SAS interface on these drives supports full duplex data transfer for higher performance and enterprise-level error recovery for better availability.
  • Robust durability
    Engineered to withstand tough conditions, the Lenovo ThinkSystem PM1645a Mainstream solid state drive has an impressive MTBF of 2,000,000 hours, ensuring reliability and longevity. Its robust design is complemented by a comprehensive range of compliance standards including BSMI, C-Tick, CB, FCC, IC, KCC, RoHS, TUV, UL, and VCCI, making it a reliable choice for any enterprise environment.
  • High performance
    With an internal data rate of 1000 MBps for both reading and writing operations, and 4KB random read and write IOPS of 230,000 and 90,000 respectively, this SSD delivers high-speed performance for rigorous enterprise applications. The drive's 800 GB capacity and 1.2 GBps data transfer rate further enhance its capability to handle large volumes of data efficiently.
  • Advanced features
    The Lenovo ThinkSystem PM1645a Mainstream SSD is equipped with advanced features such as end-to-end data protection, Tagged Command Queuing (TCQ), and power loss data protection. These features ensure the integrity and safety of your data, even in the event of unexpected power outages, making it a suitable solution for critical business operations.
Lenovo ThinkSystem PM1645a Mainstream - SSD - 800 GB - SAS 12Gb/s
Solid state drive - hot-swap
800 GB
2.5"
SAS 12Gb/s
Data Transfer Rate
1.2 GBps
End-to-end data protection, power loss data protection, Tagged Command Queuing (TCQ), S.M.A.R.T.
70 mm x 100 mm x 15 mm
140 g
1-year warranty
ThinkAgile HX1330 Appliance; HX1331 Certified Node; HX2330 Appliance; HX2331 Certified Node; HX33XX Appliance; HX33XX Certified Node; HX5530 Appliance; HX5531 Certified Node; HX7530 Appliance; HX7531 Certified Node; MX3330-F Appliance; MX3330-H Appliance; MX3331-F Certified Node; MX3331-H Certified Node; MX3530-H Hybrid Appliance; MX3531-H Hybrid Certified Node; ThinkAgile VX Certified Node 7Y94, 7Z12; ThinkAgile VX3331; VX33XX Appliance; VX3530-G Appliance; VX3575-G Integrated System; VX3720 Appliance; VX5575 Integrated System; VX7575 Integrated System; VX75XX Appliance; VX75XX Certified Node; VX7820 Appliance; ThinkSystem SR630 V2; SR645; SR650 V2; SR670 V2; SR850 V2; SR860 V2; ST650 V2
800 GB
2.5"
SAS 12Gb/s
70 mm
100 mm
15 mm
140 g
Performance
Drive Writes Per Day (DWPD)
3
SSD Endurance
4380 TB
Drive Transfer Rate
1.2 GBps (external)
Internal Data Rate
1000 MBps (read) / 1000 MBps (write)
4KB Random Read
230000 IOPS
4KB Random Write
90000 IOPS
Average Latency
45 µs
Reliability
MTBF
2,000,000 hours
Non-Recoverable Errors
1 per 10^17
Expansion & Connectivity
1 x SAS 12 Gb/s
Compatible Bay
2.5"
Power Consumption
9 watt (read) , 9 watt (write)
Hot-plug tray
UL, TUV, FCC, IC, CB, C-Tick, BSMI, KCC, VCCI, RoHS
Shipping Width
13.3 cm
Shipping Depth
17.4 cm
Shipping Height
6.3 cm
Limited warranty - replacement - 1 year
70 °C
5 - 95% (non-condensing)
Shock Tolerance (non-operating)
1500 g @ 0.5 ms
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Lenovo ThinkAgile HX1330 Appliance 7Z85 (2.5") , Lenovo ThinkAgile HX1331 Certified Node 7D52 (2.5") , Lenovo ThinkAgile HX2330 Appliance 7Z85 (2.5") , Lenovo ThinkAgile HX2331 Certified Node 7D52 (2.5") , Lenovo ThinkAgile HX3330 Appliance 7Z85 (2.5") , Lenovo ThinkAgile HX3331 Certified Node 7D52 (2.5") , Lenovo ThinkAgile HX3375 Appliance 7D5U (2.5") , Lenovo ThinkAgile HX3376 Certified Node 7D5U (2.5") , Lenovo ThinkAgile HX5530 Appliance 7Z82 (2.5") , Lenovo ThinkAgile HX5531 Certified Node 7Z84 (2.5") , Lenovo ThinkAgile HX7530 Appliance 7Z82 (2.5") , Lenovo ThinkAgile HX7531 Certified Node 7Z84 (2.5") , Lenovo ThinkAgile MX3330-F Appliance 7D19 (2.5") , Lenovo ThinkAgile MX3330-H Appliance 7D19 (2.5") , Lenovo ThinkAgile MX3331-F Certified Node 7D67 (2.5") , Lenovo ThinkAgile MX3331-H Certified Node 7D67 (2.5") , Lenovo ThinkAgile MX3530-H Hybrid Appliance 7D6B (2.5") , Lenovo ThinkAgile MX3531-H Hybrid Certified Node 7D66 (2.5") , Lenovo ThinkAgile VX Certified Node 7Y94 (2.5"), 7Z12 (2.5") , Lenovo ThinkAgile VX3320 Appliance 7Y93 (2.5") , Lenovo ThinkAgile VX3330 Appliance 7Z62 (2.5") , Lenovo ThinkAgile VX3331 7Z62 (2.5") , Lenovo ThinkAgile VX3530-G Appliance 7Z63 (2.5") , Lenovo ThinkAgile VX3575-G Integrated System 7D43 (2.5") , Lenovo ThinkAgile VX5575 Integrated System 7D43 (2.5") , Lenovo ThinkAgile VX7520 Appliance 7Y94 (2.5") , Lenovo ThinkAgile VX7530 Appliance 7Z63 (2.5") , Lenovo ThinkAgile VX7531 Certified Node 7Z63 (2.5") , Lenovo ThinkAgile VX7575 Integrated System 7D43 (2.5") , Lenovo ThinkAgile VX7576 Certified Node 7D43 (2.5") , Lenovo ThinkAgile VX7820 Appliance 7Z13 (2.5") , Lenovo ThinkSystem SR630 V2 7Z71 (2.5") , Lenovo ThinkSystem SR650 V2 7D15 (2.5"), 7Z73 (2.5") , Lenovo ThinkSystem SR670 V2 7Z23 (2.5") , Lenovo ThinkSystem SR850 V2 7D32 (2.5") , Lenovo ThinkSystem SR860 V2 7Z60 (2.5") , Lenovo ThinkSystem ST650 V2 7Z74 (2.5"), 7Z75 (2.5")
Form Factor: 2.5
Capacity: 800GB
Brand: Lenovo
Price Range Ex VAT: £750 - £1000
