The most powerful and flexible dual-processor workstation, designed for top performance and supporting the latest and most advanced GPU processing and storage technologies.
Power to burn
The ThinkStation P920 boasts the unbeatable performance of an Intel Xeon processor and P5000 GPU - an industry exclusive. That means it has the power and speed to handle your workload with ease - including the toughest ISV-certified applications. -
Unparalleled versatility
The ThinkStation P920 features a superior modular design, including Flex Trays that hold up to two drives per bay. Configure only the components you need for the ultimate in usability and savings. -
Built to last
Patented Tri-Channel Cooling ensures each component receives cool air, using a unique air baffle. The ThinkStation P920 uses fewer fans and stays cooler than the competition, so it continues to run for less downtime and a bigger bottom line. -
Easy to enhance
Intuitive red touch points guide you to quick and easy component changes - even to the motherboard and swappable power supply - without having to use a single tool. And best-of-breed cable management means no wires or plugs, and superior serviceability.
- Lenovo ThinkStation P920 - tower - Xeon Silver 4114 2.2 GHz - 32 GB - SSD 512 GB - UK
- Workstation - tower
- Localisation
- Processor
- 2 x Intel Xeon Silver 4114 / 2.2 GHz (, up to 3 GHz, (10-core)
- Cache Memory
- 27.5 MB
- Cache Per Processor
- 13.75 MB
- RAM
- 32 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- SSD 512 GB - SATA 6Gb/s - 2.5" - TCG Opal Encryption
- Optical Storage
- DVD-Writer
- Card Reader
- 9 in 1
- Networking
- 1GbE
- Keyboard
- UK
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 20 cm x 62 cm x 44.6 cm
- 31 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- TCO Certified Desktops 8
- Limited warranty - 3 years - on-site
- Workstation
- Product Form Factor
- Tower
- Built-in Devices
- 4-digit diagnostic display
- Embedded Security
- Trusted Platform Module (TPM 1.2 and TPM 2.0)
- Localisation
Processor / Chipset
- CPU
- Intel Xeon Silver 4114
- Clock Speed
- 2.2 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 10-core
- CPU Qty
- 2
- Max CPU Qty
- 2
- Chipset Type
- Intel C621
Cache Memory
- Installed Size
- 27.5 MB
- 13.75 MB
RAM
- Installed Size
- 32 GB / 512 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 2666 MHz
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 12 (empty)
- Registered, mixing of different types of memory modules is not supported, 6-channel memory architecture
- Configuration Features
- 4 x 8 GB
- RAM Supported
- 512 GB registered - ECC , 1 TB Load-Reduced - ECC
Hard Drive
- SSD - 2.5"
- Capacity
- 1 x 512 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Audio Output
- High Definition Audio
Input Device
- Mouse, keyboard
Keyboard
- Interface
- USB
- Localization & Layout
- UK
Mouse
- Technology
- Optical
- Interface
- USB
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM, I210-AT
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 3 (total) / 2 (free) x external 5.25" x 1/2H , 4 (total) / 3 (free) x internal 3.5"
- Slots
- 16 (total) / 12 (free) x DIMM 288-pin , 2 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height, double-width , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height, double-width (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (2 processors must be installed) , 3 (total) / 3 (free) x PCIe 3.0 x4 - full-length, full-height (open ended) , 2 (total) / 2 (free) x M.2 Card
- 8 x USB 3.0 (4 front, 4 rear) (one of them is 11W charging) , 1 x headphones/microphone (1 in front) , 2 x USB 2.0 , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
- Security Slot Type
- Kensington security slot
- RoHS, GREENGUARD
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 1400 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 92%
Operating System / Software
- OS Provided
Sustainability Information
- TCO Certified
- 20 cm
- 62 cm
- 44.6 cm
- 31 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
Monitors (4)
Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor | In Stock | £202.02 |
Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor | In Stock | £454.54 |
Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor | In Stock | £336.70 |
Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor | In Stock | £321.24 |
Keyboards and Mice (2)
Lenovo Professional Wireless Keyboard | In Stock | £54.36 |
Lenovo Essential Wired Keyboard and Mouse Combo - UK English | In Stock | £25.39 |
Other bundles (2)
Lenovo ThinkPad USB 3.0 Secure HDD-500GB | In Stock | £143.11 |
Kensington Security Cable Lock | In Stock | £23.65 |
