Get extreme performance from this dual-processor workhorse, powered by powerful processors and amazing graphics and featuring the most I/O in the industry. Perfect for professionals running intensive apps in the engineering & architecture, media & entertainment, oil & gas, or medical industries.
Powerful performance
Thanks to the increased performance of processors and amazing graphics, the ThinkStation P910 has the power and speed to handle your workload with ease. -
Unparalleled versatility
The ThinkStation P910 features a superior modular design, including Flex Trays holding up to two drives per bay and feature blind connection for cable-free versatility. Configure only the components you need, for the ultimate in usability and savings. -
Steadfast reliability
Tri-Channel Cooling ensures each component receives cool air, using an air baffle. The ThinkStation P910 uses fewer fans and stays cooler than the competition, so it continues to run for less downtime and a higher bottom line. -
Ease of use
Intuitive red touch points guide you to quick and easy component changes - even to the motherboard and swappable power supply - without having to use a single tool. And cable management means no wires or plugs, and superior serviceability.
- Lenovo ThinkStation P910 - tower - Xeon E5-2620V4 2.1 GHz - 32 GB - SSD 256 GB
- Workstation - tower
- Localisation
- Processor
- 2 x Intel Xeon E5-2620V4 / 2.1 GHz (, up to 3 GHz, (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2
- Cache Memory
- 40 MB
- Cache Per Processor
- 20 MB
- RAM
- 32 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC - PC4-19200
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- SSD 256 GB - SATA 6Gb/s - TCG Opal Encryption
- Optical Storage
- DVD-Writer
- Card Reader
- 9 in 1
- Graphics Controller
- No graphics
- Networking
- 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Windows 10 Pro 64-bit Edition
- 20 cm x 62 cm x 44.6 cm
- 32.3 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - 3 years - response time: next business day
- Workstation
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2620V4
- Clock Speed
- 2.1 GHz
- Max Turbo Speed
- 3 GHz
- Number of Cores
- 8-core
- CPU Qty
- 2
- Max CPU Qty
- 2
- CPU Upgradability
- Upgradable
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 40 MB
- 20 MB
RAM
- Installed Size
- 32 GB / 512 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2400 MHz
- Memory Specification Compliance
- PC4-19200
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 12 (empty)
- Registered, mixing of different types of memory modules is not supported, slots 9 - 16 are available in two-processor configuration only
- Configuration Features
- 4 x 8 GB
- RAM Supported
- 512 GB registered , 896 GB Load-Reduced
Hard Drive
- SSD
- Capacity
- 1 x 256 GB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer - SATA
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- High Definition Audio
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I218-LM, I210-AT
- Data Link Protocol
- Wake on LAN (WoL)
- Bays
- 3 (total) / 2 (free) x external 5.25" x 1/2H ¦ 4 (total) / 3 (free) x internal 3.5"
- Slots
- 16 (total) / 12 (free) x DIMM 288-pin , 2 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (2 processors must be installed) , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - full-length, full-height (2 processors must be installed) , 2 (total) / 2 (free) x PCIe 2.0 x1 - full-length, full-height , 2 (total) / 2 (free) x Flex Connector
- 8 x USB 3.0 (4 front, 4 rear) (one of them is Always On, one of them is Diagnostic) , 1 x headphones/microphone (1 in front) , 4 x USB 2.0 , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse
- RoHS, GREENGUARD
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 1300 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 92%
Operating System / Software
- OS Provided
- 20 cm
- 62 cm
- 44.6 cm
- 32.3 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
