ThinkStation P900 delivers extreme performance, as well as high storage capacity. It also delivers great technologies and design to keep your workstation cool and quiet. Maximize productivity with independent display support for up to three independent monitors using Mosaic Mode with integrated powerful graphics. With USB 3.0 ports, you can move data quickly between your workstation and other devices. The ThinkStation P900 continues the long legacy of unmatched reliability touted by Lenovo single and dual processor workstations. It's built with the same efficient thermal design and employs a cooling process that makes ThinkStation workstations stand out from the competition.
Thermal design: elegant & efficient
Patented tri-channel cooling with just 3 system fans and a direct cooling air baffle directs fresh air into the CPU and memory. ThinkStation P900 delivers great technologies and design to keep your workstation cool and quiet. -
Improved design & functionality
No more bulky handles, just a clean-looking, functional design. Integrated handles make it easier to carry and move the systems, or place into a rack. -
Multiple monitor display
Maximize productivity with independent display support for up to three independent monitors using Mosaic Mode with integrated powerful graphics. Plus, connect to up to 16 independent monitors with 1.2 stream cloning mode. -
Fast data transfer
With USB 3.0 ports, you can move data quickly between your workstation and other devices. SuperSpeed USB 3.0 enables fast file transfer, which allows for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related devices. -
Modular components & tool-free expandability
Great modular design makes tool-less upgrades a snap, especially with Flex Trays for fully configurable storage and interchangeable power supplies and graphics cards — especially beneficial when working with multiple workstations. -
Unmatched reliability
The ThinkStation P900 continues the long legacy of unmatched reliability touted by Lenovo single and dual processor workstations. It's built with the same efficient thermal design and employs a cooling process that makes ThinkStation workstations stand out from the competition. -
GREENGUARD certified
ThinkStation P900 tower is GREENGUARD certified and features a fixed power supply unit (PSU) that's 1300W and efficient.
- Lenovo ThinkStation P900 - tower - Xeon E5-2640V3 2.6 GHz - 8 GB - HDD 1 TB
- Workstation - tower - 1 USB 3.0 (Always On)
- Localisation
- Processor
- 2 x Intel Xeon E5-2640V3 / 2.6 GHz (, up to 3.4 GHz, (8-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 40 MB
- Cache Per Processor
- 20 MB
- RAM
- 8 GB (installed) / 512 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 9 in 1
- Graphics Controller
- No graphics
- Audio Output
- Stereo
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 20 cm x 62 cm x 44.6 cm
- 29.9 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - 3 years
- Workstation
- Product Form Factor
- Tower
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-2640V3
- Clock Speed
- 2.6 GHz
- Max Turbo Speed
- 3.4 GHz
- Number of Cores
- 8-core
- CPU Qty
- 2
- Max CPU Qty
- 2
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 40 MB
- 20 MB
RAM
- Installed Size
- 8 GB / 512 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 1866 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 16 (Total) / 14 (empty)
- Registered, mixing of different types of memory modules is not supported, 8-channel memory architecture
- Configuration Features
- 2 x 4 GB
- RAM Supported
- 512 GB registered , 1 TB Load-Reduced
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x RAID
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer - SATA
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Sound Output Mode
- Stereo
- High Definition Audio
- Ethernet Ports
- 2 x Gigabit Ethernet
- Ethernet Controller
- Intel I217-LM, I210-AT
- Data Link Protocol
- Bays
- 3 (total) / 2 (free) x external 5.25" , 4 (total) / 3 (free) x internal 3.5" x 1/3H
- Slots
- 16 (total) / 14 (free) x DIMM 288-pin , 2 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x4 - full-length, full-height , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (2 processors must be installed)
- 8 x USB 3.0 (4 front, 4 rear) , 1 x headphones/microphone (1 in front) , 1 x serial , 2 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse , 4 x USB 2.0
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 1300 Watt
- 80 PLUS Certification
- 80 PLUS Platinum
- Efficiency
- 92%
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 20 cm
- 62 cm
- 44.6 cm
- 29.9 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
