Lenovo ThinkStation P720 Intel Xeon Silver 4114 16GB 512GB SSD Windows 10 Professional 64-bit
Quicklinx: FPSYWS00 Mfr#: 30BA00BXUK
This dual-processor workstation is a tough performer. Ideal for professionals with heavy data-processing needs, the P720 offers fast processing, massive storage options, and parallel-processing capability.
  • Unparalleled versatility
    The ThinkStation P720 features a superior modular design, including Flex Trays that hold up to two drives per bay for versatility. Configure only the components you need, for the ultimate in usability and savings.
  • Built to last
    The Tri-Channel Cooling ensures each component receives cool air. A smaller, redesigned air baffle offers protection for high-density memory configurations. And the ThinkStation P720 uses fewer fans and stays cooler than the competition, so it continues to run for less downtime and a higher bottom line.
  • Easy to enhance
    Intuitive touch points guide you to quick and easy component changes - even to the motherboard and swappable power supply - without having to use a single tool. And excellent cable management means no wires or plugs, and superior serviceability.
Lenovo ThinkStation P720 - tower - Xeon Silver 4114 2.2 GHz - 16 GB - SSD 512 GB - UK
Workstation - tower
1 x Intel Xeon Silver 4114 / 2.2 GHz (, up to 3 GHz, (10-core)
Processor Socket
FCLGA3647 Socket
Processor Main Features
Hyper-Threading Technology, Intel Virtualization Technology, Intel Turbo Boost Technology 2
Cache Memory
13.75 MB
Cache Per Processor
13.75 MB
RAM
16 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
SSD 512 GB - SATA 6Gb/s - 2.5" - TCG Opal Encryption
Optical Storage
DVD-Writer
Card Reader
9 in 1
Graphics Controller
No graphics
1GbE
Keyboard
OS Provided
Windows 10 Pro for Workstations 64-bit Edition
17.5 cm x 48.5 cm x 44.6 cm
23.7 kg
Manufacturer Selling Program
TopSeller
Limited warranty - 3 years - on-site - response time: next business day
Workstation
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 1.2 and TPM 2.0)
Processor / Chipset
CPU
Clock Speed
2.2 GHz
Max Turbo Speed
3 GHz
Number of Cores
10-core
CPU Qty
1
Max CPU Qty
2
CPU Socket
FCLGA3647 Socket
Chipset Type
Intel C621
Cache Memory
Installed Size
13.75 MB
Cache Per Processor
13.75 MB
RAM
Installed Size
16 GB / 384 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
2666 MHz
DIMM 288-pin
Slots
12 (Total) / 11 (empty)
Registered, slots 7 - 12 are available in two-processor configuration only
Configuration Features
1 x 16 GB
Hard Drive
SSD - 2.5"
1 x 512 GB
Interface Type
SATA 6Gb/s
TCG Opal Encryption
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer
Card Reader
9 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Ports
2 x Gigabit Ethernet
Ethernet Controller
Intel I219-LM, I210-AT
Wake on LAN (WoL), Intel Active Management Technology (AMT) 11
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , Internal 3.5"
Slots
1 (total) / 1 (free) x PCIe 3.0 x16 - full-length, full-height (2 processors must be installed) , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height (double-width) , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (open ended) , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height (open ended) , 2 (total) / 2 (free) x M.2 Card
8 x USB 3.0 (4 front, 4 rear) (one of them is charging) , 1 x headphones/microphone (1 in front) , 2 x USB 2.0 , 2 x LAN (Gigabit Ethernet) , 1 x microphone , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, GREENGUARD
TopSeller
Power supply
Power Provided
900 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
92%
Operating System / Software
OS Provided
Windows 10 Pro for Workstations 64-bit Edition English
17.5 cm
48.5 cm
44.6 cm
23.7 kg
10 °C
35 °C
10 - 80% (non-condensing)
Monitors (5)
FPSY Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.47
FPSY Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
FPSY Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
FPSY Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £312.68
FPSY Lenovo Tiny-in-One 22 21.5" 1920 x 1080 14ms Full HD LED monitor In Stock £177.78
Keyboards and Mice (3)
FPSY Lenovo Professional Wireless Keyboard In Stock £53.21
FPSY Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
FPSY Lenovo ThinkPad Bluetooth Silent Mouse - Right and Left-handed In Stock £23.88
Other bundles (6)
FPSY Lenovo Mini Displayport to Displayport Cable In Stock £15.46
FPSY Lenovo ThinkPad USB 3.0 Secure HDD-500GB In Stock £143.11
FPSY Lenovo MiniDisplayPort to HDMI Cable In Stock £17.02
FPSY Kensington Security Cable Lock In Stock £23.65
FPSY Lenovo 100 Headset on ear wired - USB black for IdeaPad 3 ThinkCe In Stock £34.84
FPSY Lenovo Thinkvision MC50 Monitor Webcam In Stock £53.85
