Lenovo ThinkStation P520c Intel Xeon W-2123 16GB 512GB SSD Windows 10 Professional 64-bit
Quicklinx: FGJSWS00 Mfr#: 30BX004JUK
  • Xeon
A next-generation mainstream workstation that's powerful enough for any job and reliable enough for mission-critical environments. From handling large workloads to multitasking with ease, the ThinkStation P520c takes everything in its stride. Energy-efficient and extremely reliable, it's also ISV-certified, VR-ready and now comes with super-fast dual-M.2 NVMe support directly on the motherboard.
  • Real power
    For true processing power and fast visuals, power up the ThinkStation P520c. Fueled by modern processors and graphics, this compact workhorse can help you to get the job done, quickly and easily.
  • Configurable and reliable
    The P520c can be configured to meet your specific needs. However you configure your P520c, ThinkStation workstations are well known for their reliability.
  • Enhanced flexible design
    With M.2 PCIe solid state drive slots embedded on the motherboard, you can enjoy fast storage speeds. What's more, the front FLEX module gives you a range of options and flexibility, including a media card reader, optical drives, and a variety of additional front access I/O ports.
Lenovo ThinkStation P520c - tower Xeon W-2123 3.6 GHz - 16 GB - SSD 512 GB - UK
Workstation - tower
1 x Intel Xeon W-2123 / 3.6 GHz (Quad-Core)
Cache Memory
8.25 MB
Cache Per Processor
8.25 MB
RAM
16 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s)
Hard Drive
SSD 512 GB - PCI Express - M.2 - TCG Opal Encryption
Optical Storage
DVD-Writer
Card Reader
9 in 1
Graphics Controller
No graphics
1GbE
Keyboard
OS Provided
Windows 10 Pro for Workstations 64-bit Edition
17.5 cm x 42.6 cm x 37.6 cm
14.5 kg
Manufacturer Selling Program
Lenovo TopSeller
Limited warranty - 3 years - on-site - response time: next business day
Workstation
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 1.2 and TPM 2.0)
Processor / Chipset
CPU
Intel Xeon W-2123
Clock Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel C422
Cache Memory
Installed Size
8.25 MB
Cache Per Processor
8.25 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
2666 MHz
Rated Memory Speed
1333 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Registered, quad channel memory architecture
Configuration Features
1 x 16 GB
Hard Drive
SSD - M.2
1 x 512 GB
Interface Type
PCI Express
TCG Opal Encryption
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
DVD-Writer
Card Reader
9 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), Intel Active Management Technology (AMT) 11
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 2 (total) / 2 (free) x internal 3.5"
Slots
2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (open ended) , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height (open ended) , 2 (total) / 1 (free) x M.2 Card
6 x USB 3.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 2 x microphone (1 front, 1 rear) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop
Security Slot Type
Kensington security slot
RoHS, GREENGUARD
Lenovo TopSeller
Power supply
Power Provided
500 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
92%
Operating System / Software
OS Provided
17.5 cm
42.6 cm
37.6 cm
14.5 kg
10 °C
35 °C
10 - 80% (non-condensing)
FGJS Lenovo Mini Displayport to Displayport Cable In Stock £15.38
FGJS Lenovo MiniDisplayPort to HDMI Cable In Stock £16.86
FGJS Kensington Security Cable Lock In Stock £23.92
