Lenovo ThinkStation P520c Intel Xeon W-2104 8GB 1TB Windows 10 Professional 64-bit
Quicklinx: FGJQWS00 Mfr#: 30BX004SUK
  • Xeon
From large workloads to multitasking, the compact ThinkStation P520c breezes through it all. With fast processing, graphics, storage, and memory, this configurable workstation is a solid workhorse.
  • Real power
    For true processing power and fast visuals, power up the ThinkStation P520c. Fueled by modern processors and graphics, this compact workhorse can help you to get the job done, quickly and easily.
  • Configurable and reliable
    The P520c can be configured to meet your specific needs. However you configure your P520c, ThinkStation workstations are well known for their reliability.
  • Enhanced flexible design
    With M.2 PCIe solid state drive slots embedded on the motherboard, you can enjoy fast storage speeds. What's more, the front FLEX module gives you a range of options and flexibility, including a media card reader, optical drives, and a variety of additional front access I/O ports.
Lenovo ThinkStation P520c - tower Xeon W-2104 3.2 GHz - 8 GB - HDD 1 TB - UK
Workstation - tower
1 x Intel Xeon W-2104 / 3.2 GHz (Quad-Core)
Cache Memory
8.25 MB
Cache Per Processor
8.25 MB
RAM
8 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC
Storage Controller
RAID (SATA 6Gb/s); RAID
Hard Drive
HDD 1 TB - SATA 6Gb/s - 7200 rpm
Optical Storage
DVD-Writer
Card Reader
Graphics Controller
No graphics
1GbE
Keyboard
OS Provided
Windows 10 Pro for Workstations 64-bit Edition
17.5 cm x 42.6 cm x 37.6 cm
14.5 kg
Manufacturer Selling Program
Lenovo TopSeller
Limited warranty - 3 years - on-site - response time: next business day
Workstation
Product Form Factor
Tower
Embedded Security
Trusted Platform Module (TPM 1.2 and TPM 2.0)
Processor / Chipset
CPU
Intel Xeon W-2104
Clock Speed
3.2 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel C422
Cache Memory
Installed Size
8.25 MB
Cache Per Processor
8.25 MB
RAM
Installed Size
DDR4 SDRAM - ECC
Effective Memory Speed
2400 MHz
Rated Memory Speed
1200 MHz
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Registered, quad channel memory architecture
Configuration Features
1 x 8 GB
Hard Drive
HDD
1 x 1 TB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x RAID
Controller Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10
Storage Controller (2nd)
1 x RAID
RAID Level
RAID 0, RAID 1
Optical Storage
DVD-Writer - SATA
Card Reader
Card reader
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
No graphics
Audio Output
High Definition Audio
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Mouse Name
Lenovo Calliope Mouse
USB
Ethernet Controller
Intel I219-LM
Wake on LAN (WoL), Intel Active Management Technology (AMT) 11
Bays
2 (total) / 1 (free) x external 5.25" x 1/2H , 2 (total) / 1 (free) x internal 3.5"
Slots
2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x8 - full-length, full-height (open ended) , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height (open ended) , 2 (total) / 1 (free) x M.2 Card
6 x USB 3.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 2 x microphone (1 front, 1 rear) , 2 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial
Theft/Intrusion Protection
Security lock slot (cable lock sold separately), padlock loop, chassis intrusion switch
Security Slot Type
Kensington security slot
RoHS, GREENGUARD
Lenovo TopSeller
Power supply
Power Provided
500 Watt
80 PLUS Certification
80 PLUS Platinum
Efficiency
92%
Operating System / Software
OS Provided
Windows 10 Pro for Workstations 64-bit Edition English
17.5 cm
42.6 cm
37.6 cm
14.5 kg
10 °C
35 °C
10 - 80% (non-condensing)
FGJQ Lenovo Mini Displayport to Displayport Cable In Stock £15.32
FGJQ APC Smart-UPS SMC1000IC - UPS - AC 220/230/240 V - 600 Watt In Stock £444.92
FGJQ Kensington Security Cable Lock In Stock £23.88
FGJQ APC BACK UPS PRO BR900MI 900VA 6 Outlets In Stock £205.83
FGJQ APC BACK UPS PRO BR1300MI 1300VA 8 Outlets In Stock £295.56
FGJQ APC BACK UPS PRO BR1600MI 1600VA 8 Outlets In Stock £362.88
