A next-generation workstation that's powerful enough for any job and reliable enough for mission-critical environments. Customise a ThinkStation P500 for the power, performance and usability you need, including the highest storage capacity available. Intelligent design features include new Flex Tray that holds up to two drives for total flexibility and patented Tri-Channel Cooling for enhanced reliability.
Thermal design
ThinkStation P500 delivers technologies and design to keep your workstation cool and quiet. -
Multiple monitor display
Maximize productivity with independent display support for independent monitors using Mosaic Mode with integrated graphics. -
Fast data transfer
With USB 3.0 ports, you can move data quickly between your workstation and other devices. SuperSpeed USB 3.0 enables file transfer faster than previous USB technologies, which allows for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related devices. -
Modular components
Innovative modular design makes tool-less upgrades a snap, especially with Flex Trays for fully configurable storage and interchangeable power supplies and graphics cards - especially beneficial when working with multiple workstations. -
Unmatched reliability
The ThinkStation P500 continues the long legacy of unmatched reliability touted by Lenovo single and dual processor workstations. It's built with the same efficient thermal design and employs a cooling process that makes ThinkStation workstations stand out from the competition. -
Green Leadership
ThinkStation P500 tower is Greenguard certified and features a fixed power supply unit.
- Lenovo ThinkStation P500 - tower - Xeon E5-1650V3 3.5 GHz - 8 GB - SSD 128 GB, HDD 1 TB
- Workstation - tower - 1 USB 3.0 (Always On)
- Localisation
- Processor
- 1 x Intel Xeon E5-1650V3 / 3.5 GHz (, up to 3.8 GHz, (6-core)
- Processor Socket
- LGA2011-v3 Socket
- Processor Main Features
- Hyper-Threading Technology, Intel Turbo Boost Technology 2, Intel Smart Cache
- Cache Memory
- 15 MB
- Cache Per Processor
- 15 MB
- RAM
- 8 GB (installed) / 256 GB (max) - DDR4 SDRAM - ECC - PC4-17000
- Storage Controller
- RAID (SATA 6Gb/s)
- Hard Drive
- SSD 128 GB - SATA 6Gb/s
- Hard Drive (2nd)
- HDD 1 TB - SATA 6Gb/s - 7200 rpm
- Optical Storage
- DVD-Writer
- Card Reader
- 9 in 1
- Graphics Controller
- No graphics
- Audio Output
- Stereo - integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 17.5 cm x 47 cm x 44 cm
- 22.2 kg
- Manufacturer Selling Program
- TopSeller
- Limited warranty - 3 years
- Workstation
- Product Form Factor
- Tower
- Built-in Devices
- Speaker
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E5-1650V3
- Clock Speed
- 3.5 GHz
- Max Turbo Speed
- 3.8 GHz
- Number of Cores
- 6-core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA2011-v3 Socket
- Chipset Type
- Intel C612
Cache Memory
- Installed Size
- 15 MB
- 15 MB
RAM
- Installed Size
- 8 GB / 256 GB (max)
- Technology
- DDR4 SDRAM - ECC
- Effective Memory Speed
- 2133 MHz
- Rated Memory Speed
- 2133 MHz
- Memory Specification Compliance
- PC4-17000
- Form Factor
- DIMM 288-pin
- Slots
- 8 (Total) / 6 (empty)
- Registered, quad channel memory architecture, mixing of different types of memory modules is not supported
- Configuration Features
- 2 x 4 GB
- RAM Supported
- 256 GB registered - ECC , 512 GB Load-Reduced - ECC
Hard Drive
- SSD
- Capacity
- 1 x 128 GB
- Interface Type
- SATA 6Gb/s
Hard Drive (2nd)
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer
Card Reader
- 9 in 1 card reader
Monitor
- Monitor Type
- None.
Graphics Controller
- Graphics Processor
- No graphics
Audio Output
- Integrated
- Sound Output Mode
- Stereo
- High Definition Audio
- Integrated
- Ethernet Controller
- Intel I217-LM
- Data Link Protocol
- Bays
- 2 (total) / 1 (free) x external 5.25" x 1/2H , 4 (total) / 2 (free) x internal 3.5" x 1/3H
- Slots
- 8 (total) / 6 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x16 - full-length, full-height , 1 (total) / 1 (free) x PCIe 3.0 x4 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - full-length, full-height , 1 (total) / 1 (free) x PCI - full-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x4 - half-length, full-height
- 8 x USB 3.0 (4 front, 4 rear) , 1 x headphones/microphone (1 in front) , 1 x microphone , 4 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x PS/2 keyboard , 1 x PS/2 mouse
- Included Accessories
- Lenovo recovery disk flyer
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 490 Watt
- 80 PLUS Certification
- 80 PLUS Gold
Operating System / Software
- OS Provided
- Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
- 17.5 cm
- 47 cm
- 44 cm
- 22.2 kg
- 10 °C
- 35 °C
- 10 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.08 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £19.26 |
