Say hello to ThinkSmart Hub 500. Easy to deploy and use, this all-in-one, purpose-built Skype Room Systems device is the key to more efficient meetings. Start on time, every time with one tap of your finger. Hear what everyone has to say, loud and clear. And see the difference this makes to your productivity - and bottom line.
Because everyone's time is valuable
Meetings are time consuming enough without trying to get the technology to work properly. The average delay is around 10 minutes, but with the ThinkSmart Hub 500, you can avoid costly late starts. As audio and video is already connected, simply hit one button and everyone can begin collaborating right away. -
A better way for teams to work together
A key feature of the ThinkSmart Hub 500 is its eye-catching anti-glare, anti-smudge display. Rotatable through 360°, anyone within arm reach can take and give control instantly, enabling meetings to run more smoothly - and more fairly. There's also a 3-color LED ring that lets everyone in the room know the status of the call. -
Simplify meetings, worldwide
Whether you're a host or attendee, the ThinkSmart Hub 500 will make your life easier. Eeveryone in your organization will be familiar with the system wherever your business takes them.
- Lenovo ThinkSmart Hub 500 - for Microsoft Teams - all-in-one Core i5 7500T 2.7 GHz - 8 GB - SSD 128 GB - LED 11.6"
- Personal computer - all-in-one
- Bundled Services
- 3 Years Lenovo Premier Support
- Localisation
- Processor
- Intel Core i5 (7th Gen) 7500T / 2.7 GHz (up to 3.3 GHz, (Quad-Core)
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 6 MB
- Cache Per Processor
- 6 MB
- RAM
- 8 GB DDR4 SDRAM
- Hard Drive
- SSD 128 GB - M.2
- Optical Storage
- No optical drive
- Monitor
- 11.6" - LED - 1920 x 1080 (Full HD) - 16:9 - touchscreen
- Graphics Controller
- Intel HD Graphics 630
- Networking
- 1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, Bluetooth 4.1
- OS Provided
- Windows 10 IoT Enterprise CBB 64-bit Edition
- Software Included
- Skype Room Systems
- 19.3 cm x 27.9 cm x 17.6 cm
- 2.5 kg
- Manufacturer Selling Program
- Lenovo TopSeller
- Limited warranty - 3 years - on-site
- Personal computer
- Bundled Services
- Product Form Factor
- All-in-one
- Built-in Devices
- Stereo speakers, 3-colour LED ring
- Sensors
- Proximity sensor
- Localisation
Processor / Chipset
- CPU
- Clock Speed
- 2.7 GHz
- Max Turbo Speed
- 3.3 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
Cache Memory
- Installed Size
- 6 MB
- 6 MB
RAM
- Installed Size
- 8 GB
- Technology
- DDR4 SDRAM
- Effective Memory Speed
- 2400 MHz
- Rated Memory Speed
- 1200 MHz
- Configuration Features
- 2 x 4 GB
Hard Drive
- SSD - M.2
- Capacity
- 1 x 128 GB
Optical Storage
- No optical drive
Monitor
- Monitor Type
- LED
- Touchscreen
- Yes (10-point multi-touch)
- Diagonal Size
- 11.6"
- Native Resolution
- Widescreen Display
- Image Aspect Ratio
- 16:9
- Image Brightness
- 300 cd/m²
- Monitor Features
- Anti-glare, 360° rotatable
Graphics Controller
- Graphics Processor
- Video Interfaces
- HDMI
Audio Output
- Dolby Audio Premium
- Speakers Included
- 2 x right / left channel
Input Device
- No keyboard, no mouse
Audio Input
- Two microphones
- Wireless LAN Supported
- Wireless NIC
- Intel Dual Band Wireless-AC 8265
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 4.1
- 4 x USB 3.0 , 1 x HDMI input , 2 x HDMI output , 1 x headphones/microphone , 1 x LAN (Gigabit Ethernet)
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Lenovo TopSeller
- Power adapter
- Power Provided
- 90 Watt
- Efficiency
- 88%
Operating System / Software
- OS Provided
- Software
- 19.3 cm
- 27.9 cm
- 17.6 cm
- 2.5 kg
Lenovo ePac OnSite Repair Extended Service Agreement 5 Years | In Stock | £88.93 |
