If your business is moving up from a desktop environment to its first server, you'll find everything you need in the TS140 - an affordable, durable server with impeccable productivity and manageability features.
The TS140 makes clever use of Intel AMT 9.0 to provide out-of-band, cost-effective, remote management of end-user environments - regardless of the managed server's status. Intuitive and secure, the web console works directly out of the box to give point-and-click management tools perfect for branch offices or remote deployments with limited IT resources.
At 26 dB, the acoustics of the TS140 are impressively quiet for any server - that's less noise than you'll find in a typical library. Plus, it's ENERGY STAR-certified, so it's easy on the environment and easy on your power bills.
Productivity boost
Thanks to the increased performance of the latest Intel Xeon processor, with Turbo Boost 2.0, onboard RAID 0/1/10/5 data protection, and powerful HD graphics performance, the TS140 has the power and speed to handle your workload with ease - while keeping your data safe. -
Ample networking and storage capacity
The TS140 offers storage and scalability for businesses large and small. -
Resourceful manageability features
The TS140 makes clever use of Intel AMT 9.0 to provide out-of-band, cost-effective, remote management of end-user environments - regardless of the managed server's status. Intuitive and secure, the web console works directly out of the box to give point-and-click management tools perfect for branch offices or remote deployments with limited IT resources. -
Whisper-quiet, energy-efficient operation
At 26 dB, the acoustics of the TS140 are impressively quiet for any server - that's less noise than you'll find in a typical library. Plus, it's ENERGY STAR-certified, so it's easy on the environment and easy on your power bills. -
True server-class features
Rely on features like ECC memory, enterprise-class hard drives, and built-in RAID for maximum uptime - the TS140 is designed for 24 x 7 run times and true server reliability. -
Superb value
With its attractive price points and low operating costs, the TS140 is highly affordable for the features and functionality it offers.
- Lenovo ThinkServer TS140 - tower - Xeon E3-1226V3 3.3 GHz - 8 GB - HDD 2 x 1 TB
- Server - tower - power-on password, serial port I/O control, USB port control, boot sequence control, Intel Active Management Technology (iAMT), boot without keyboard or mouse or diskette, rack-mountable
- Height (Rack Units)
- 4U
- Localisation
- Server Scalability
- 1-way
- Processor
- 1 x Intel Xeon E3-1226V3 / 3.3 GHz (, up to 3.7 GHz, (Quad-Core)
- Processor Socket
- LGA1150 Socket
- Processor Main Features
- Intel Turbo Boost Technology 2
- Cache Memory
- 8 MB
- Cache Per Processor
- 8 MB
- RAM
- 8 GB (installed) / 32 GB (max) - DDR3 SDRAM - ECC - PC3-12800
- Storage Controller
- RAID (SATA 6Gb/s) (ThinkServer RAID 100)
- Hard Drive
- 2 x HDD 1 TB - SATA 6Gb/s
- Optical Storage
- DVD-Writer
- Graphics Controller
- Intel HD Graphics P4600
- Audio Output
- Integrated
- Networking
- GigE
- Power
- AC 120/230 V (50/60 Hz)
- Raven black
- 17.5 cm x 43.1 cm x 37.5 cm
- 13 kg
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - on-site
- Server
- Product Form Factor
- Tower - 4U
- Embedded Security
- Trusted Platform Module (TPM 1.2) Security Chip
- 1-way
- Internal Bays Qty
- 2
- Front Accessible Bays Qty
- 1
- Raven black
- Localisation
Processor / Chipset
- CPU
- Intel Xeon E3-1226V3
- Clock Speed
- 3.3 GHz
- Max Turbo Speed
- 3.7 GHz
- Number of Cores
- Quad-Core
- CPU Qty
- 1
- Max CPU Qty
- 1
- CPU Socket
- LGA1150 Socket
- Chipset Type
- Intel C226
Cache Memory
- Installed Size
- 8 MB
- 8 MB
RAM
- Installed Size
- 8 GB / 32 GB (max)
- Technology
- DDR3 SDRAM - ECC
- Effective Memory Speed
- 1600 MHz
- Rated Memory Speed
- 1600 MHz
- Memory Specification Compliance
- PC3-12800
- Form Factor
- DIMM 240-pin
- Slots
- 4 (Total) / 3 (empty)
- Unbuffered
- Configuration Features
- 1 x 8 GB
Hard Drive
- HDD
- Capacity
- 2 x 1 TB
- Interface Type
- SATA 6Gb/s
Storage Controller
- 1 x RAID - integrated
- Controller Interface Type
- SATA 6Gb/s
- Storage Controller Name
- ThinkServer RAID 100
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10
Optical Storage
- DVD-Writer - SATA
Monitor
- Monitor Type
- None.
Graphics Controller
- Integrated
- Graphics Processor
- Video Interfaces
- VGA, DisplayPort
Audio Output
- Integrated
- Integrated
- Ethernet Controller
- Intel I217
- Data Link Protocol
- Bays
- 1 (total) / 0 (free) x external 5.25" x 1/2H , 2 (total) / 0 (free) x internal 3.5" x 1/3H
- Slots
- 1 (total) / 0 (free) x CPU , 4 (total) / 3 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe 3.0 x16 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x1 - half-length, full-height , 1 (total) / 1 (free) x PCIe 2.0 x16 - half-length, full-height (x4 mode) , 1 (total) / 1 (free) x PCI - half-length, full-height
- 6 x USB 3.0 (2 front, 4 rear) , 1 x VGA , 2 x DisplayPort , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x audio line-in , 1 x audio line-out , 1 x microphone
- Power-on password, serial port I/O control, USB port control, boot sequence control, Intel Active Management Technology (iAMT), boot without keyboard or mouse or diskette, rack-mountable
- Theft/Intrusion Protection
- Security lock slot (cable lock sold separately), padlock loop
- RoHS, GREENGUARD
- TopSeller
- Power supply
- Voltage Required
- Power Provided
- 280 Watt
- 80 PLUS Certification
- 80 PLUS Bronze
Sustainability Information
- ENERGY STAR Certified
- 17.5 cm
- 43.1 cm
- 37.5 cm
- 13 kg
C2G 2m DisplayPort Male to HD Male Adapter Cable - Black | In Stock | £25.26 |
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
