Lenovo ThinkServer SA120 Storage Enclosure
Quicklinx: 9NQBWS00 Mfr#: 70F10002UK
ThinkServer SA120 direct attach storage offers enormous expansion, with twelve 3.5" high capacity front-panel drive bays, up to two I/O controllers and four optional rear-panel 2.5" SSD drive bays to improve throughput. Coupled with ThinkServer host servers configured with LSI CacheCade technology, these SSD drives enable the ThinkServer SA120 to provide additional cache, low latency and deliver amazing IOPS improvements. This clever, scalable design provides an optimal tiered storage solution.
With legendary Think design and enterprise-grade reliability, the ThinkServer SA120 provides peace of mind. Its innovative storage design combines large capacity near-line 3.5" drives and lightning-fast 2.5" drives to provide a perfect solution for customers who require high performance and maximum capacity at a fraction of the cost and complexity of typical storage area network choices. Servicing the SA120 is easy with tool-less components, hot-swap fans and power supplies. It shares common parts with ThinkServer rack and tower servers for simplified management.
Featuring the latest high performance SSD choices from Intel, ThinkServer SA120 delivers the fast response and low latency you demand. ThinkServer SA120 offers high efficiency 80 PLUS redundant power supplies to keep your business running smoothly and to reduce power consumption. Plus, if you need fast, professional service help, Lenovo provides an impressive array of warranty upgrades and rapid-response services.
  • Modular and scalable
  • Customer focused design
  • Impressive features, great value
Lenovo ThinkServer SA120 70F1 - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Max Supported Capacity
48 TB
SAS
12 (max)
Supported Drives
SAS-2
English / United Kingdom
Hard Drive
No HDD
AC 120/230 V - 50/60 Hz
Power Redundancy
48.26 cm x 39.405 cm x 8.66 cm
22 kg
3-year warranty
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
Supported Devices / Modules Qty
12
Supported Drives
SAS-2
Storage
48 TB
HDD Array External Interface
SAS
CPU
No CPU
Hard Drive
No HDD
Expansion Bays
12 (total) / 12 (free) x hot-swap - 3.5"
2 x SAS , 1 x serial - RJ-11
1 x SAS cable - 0.5 m
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
550 Watt
48.26 cm
39.405 cm
8.66 cm
22 kg
Limited warranty - 3 years - on-site
10 °C
35 °C
8 - 80% (non-condensing)
