Lenovo ThinkServer RD550 Intel Xeon E5-2660v3 8GB
Quicklinx: B05TWS00 Mfr#: 70CX000JEA
  • Xeon
Innovation is built in to the new Lenovo ThinkServer RD550. A cleverly engineered design allows more storage density and I/O connectivity than ever before - giving you the performance and capacity of a 2U system in a 1U form factor. By creating smaller drive trays and a slightly larger chassis within the same 1U space, the RD550 offers a total of up to 12 bays, which can be used for data storage or better performance. Industry-unique Lenovo AnyBay design allows multiple storage types in the same drive bay, including front-accessible PCIe SSD for ultimate performance.
  • Highly flexible I/O
    In the past, 1U servers were constrained by their size and did not have as many I/O slots as larger servers. With the new RD550, networking configurations that traditionally required a larger server can now fit into a 1U form factor. Leveraging the unique Lenovo AnyFabric design, the RD550 can house up to eight 10 Gb Ethernet ports - without taking up any of the available PCIe slots. If you include network adapters in the available slots, the RD550 can support an incredible amount of network bandwidth in a single 1U server.
  • Extra-reliable performance
    Data center cooling costs can be greater than the cost of powering the IT equipment itself. One way to reduce these cooling costs is by operating the data center at a higher temperature. With a dynamic environmental design, the RD550 can run at 45 degrees Celsius continuously - with no impact on reliability. In fact, the system has been carefully architected and tested to support long-term reliability. The RD550 is also perfect for organizations that install servers in less strictly controlled environments. Other high-reliability features include ECC memory, hot-swap hard-disk drive and SSD capability, and hot-swap and redundant power and cooling.
Lenovo ThinkServer RD550 - rack-mountable - Xeon E5-2660V3 2.6 GHz - 8 GB - no HDD
Server - rack-mountable - administrator password, power-on password
Height (Rack Units)
1U
Server Scalability
2-way
1 x Intel Xeon E5-2660V3 / 2.6 GHz (, up to 3.3 GHz, (10-core)
Processor Socket
LGA2011-v3 Socket
Processor Main Features
Hyper-Threading Technology, Intel Turbo Boost Technology 2
Cache Memory
25 MB
Cache Per Processor
25 MB
RAM
8 GB (installed) / 384 GB (max) - DDR4 SDRAM - ECC - PC4-17000
Storage Controller
RAID (SATA 6Gb/s / SAS 12Gb/s) (ThinkServer RAID 720ix AnyRAID)
Server Storage Bays
Hot-swap 2.5"
Hard Drive
No HDD
Optical Storage
No optical drive
Graphics Controller
ASPEED AST2400
Video Memory
16 MB
GigE
Power Redundancy
Optional
OS Provided
No operating system
48.2 cm x 78 cm x 4.3 cm
13.5 kg
Manufacturer Selling Program
TopSeller
Limited warranty - parts and labour - 3 years - on-site
Server
Product Form Factor
Rack-mountable - 1U
Built-in Devices
Led panel
Server Scalability
2-way
Hot-Swap Bays Qty
12
Processor / Chipset
CPU
Clock Speed
2.6 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
10-core
CPU Qty
1
Max CPU Qty
2
CPU Upgradability
Upgradable
CPU Socket
LGA2011-v3 Socket
Chipset Type
Intel C612
Cache Memory
Installed Size
25 MB
Cache Per Processor
25 MB
RAM
Installed Size
8 GB / 384 GB (max)
DDR4 SDRAM - ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
24 (Total) / 23 (empty)
Registered, Memory Mirroring, Memory Sparing, mixing of different types of memory modules is not supported, 8-channel memory architecture
Configuration Features
1 x 8 GB
RAM Supported
384 GB registered - ECC , 768 GB Load-Reduced - ECC
Hard Drive
No HDD
Storage Controller
1 x RAID - plug-in card
Controller Interface Type
Storage Controller Name
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 50, RAID 60
Buffer Size
1 GB
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
ASPEED AST2400
Video Memory
16 MB
Video Interfaces
DisplayPort
Remote Management Protocol
IPMI 2.0
Remote Management Controller
Aspeed AST2400
Bays
12 (total) / 12 (free) x hot-swap 2.5"
Slots
24 (total) / 23 (free) x DIMM 288-pin , 2 (total) / 1 (free) x CPU , 2 (total) / 2 (free) x PCIe 3.0 x8 - low-profile
2 x USB 3.0 (2 rear) , 1 x DisplayPort , 1 x serial , 4 x LAN (Gigabit Ethernet) , 1 x management - RJ-45
Administrator password, power-on password
TopSeller
Power supply - hot-plug
Power Redundancy
Optional
Power Redundancy Scheme
1+1 (with optional power supply)
Installed Qty
1
Max Supported Qty
2
Power Provided
750 Watt
80 PLUS Certification
80 PLUS Platinum
Operating System / Software
OS Provided
No operating system
48.2 cm
78 cm
4.3 cm
13.5 kg
10 °C
45 °C
20 - 80% (non-condensing)
