Coping with the demands of school life takes an especially robust and durable device. That's where the Lenovo ThinkPad 11e comes in - because it's specifically designed to cope with the rough and tumble of school use.
This 11.6" laptop features a rubber bumper around its top cover for absorbing the impact of side bumps. Its ultra-durable hinges and brackets are strong enough to last 50,000 cycles and the LCD panel is protected by both a stronger bezel and a reinforced rear panel.
The ThinkPad 11e is powered by a 1.83GHz Intel Celeron processor and features 4GB of RAM with 16GB of storage space. Its battery life of up to eight hours provides plenty of time to get those important tasks done.
It also comes equipped with all the features and software required for a rewarding and effective digital learning experience, as well as crisp audio and quick data transfer capability thanks to USB 3.0 - 10 times faster than previous USB technologies.
Rugged construction
A rubber bumper around the top cover absorbs the force of side bumps. The corners are stronger, to reduce damage when dropped at an angle. -
Integrated webcam
The webcam with face tracking, plus dual digital-array microphones, will help you enjoy web conferences or online video chats like you're really there. -
Powered USB port
Enjoy the benefits of an always-on port, charging your USB devices without having to turn on your laptop. -
HDMI output
For easy connection to a television or other display.
- Lenovo ThinkPad Yoga 11e Chromebook (1st Gen) - 11.6" - Intel Celeron - N2940 - 4 GB RAM - 16 GB eMMC - UK
- Product Type
- Chromebook - flip design
- Operating System
- Chrome OS
- Processor
- Intel Celeron N2940 / 1.83 GHz, up to 2.25 GHz / 2 MB Cache
- Memory
- 4 GB DDR3L (provided memory is soldered)
- Storage
- 16 GB eMMC
- Display
- 11.6" LED backlight touchscreen 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 4-cell - up to 8 hours
- Security
- Trusted Platform Module (TPM 1.2) Security Chip
- Graphite black
- 30 cm x 21.6 cm x 2.29 cm
- 1.5 kg
- Localisation
- Manufacturer Selling Program
- TopSeller
- Environmental Standards
- ENERGY STAR Qualified
- Limited warranty - 1 year - pick-up and return
- Product Type
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.25 GHz
- Number of Cores
- Quad-Core
- Cache
- 2 MB
- 64-bit Computing
- Integrated memory controller, Intel Burst Technology
- RAM
- 4 GB (provided memory is soldered)
- Technology
- DDR3L SDRAM
- Speed
- 1333 MHz
Storage
- Main Storage
- 16 GB eMMC
Display
- 11.6" - IPS
- LCD Backlight Technology
- LED backlight
- Touchscreen
- Yes (10-point multi-touch)
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Yes - 720p
- Sound
- Stereo speakers, microphone
- Codec
- Maxim Integrated MAX98090AETL+T
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
- Volume control, multi-touch touchpad, buttonless touchpad, Chrome keyboard
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7260 - M.2 Card
- Technology
- 4-cell Lithium Ion
- Capacity
- 35 Wh
- Run Time
- Up to 8 hours
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 45 Watt
Connections & Expansion
- USB 3.0 , USB 2.0 , HDMI , Headphone/microphone combo jack
- Memory Card Reader
- 4 in 1 (SD Card, MultiMediaCard, SDHC Card, SDXC Card)
- Graphite black
- Case Material
- Polycarbonate, polycarbonate ABS, glass-fibre reinforced plastic
- Security
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- RoHS, GREENGUARD
- Localization
- TopSeller
- 1.5 kg
Sustainability Information
- ENERGY STAR Certified
