Lenovo ThinkPad X395 Ryzen 5 PRO 16GB 256GB SSD 13.3" Windows 10 Professional 64-bit
Quicklinx: F939WS00 Mfr#: 20NL001HUK
  • IEEE 802.11n
The ThinkPad X395 easily slips into a bag or tucks under your arm. It's powered by a fast processor, which means longer battery life, faster processing, and higher power efficiency.
  • Faster, smoother, more powerful
    2nd Gen AMD Ryzen Pro APU and Vega graphics increase CPU frequency and improve GPU performance. With AMD power, your ThinkPad X395 runs more efficiently and enhances battery life and audio performance. And with AMD FreeSync, available on the FHD display, stuttering and tearing are eliminated, and dynamic frame rates are optimized-you'll enjoy videos and gaming all the more.
  • Displays that dazzle
    Choose from several display options, including an FHD IPS on-cell touchscreen for enhanced battery life, an FHD IPS non-touch screen, and an HD TN display. No matter which choice you make, the super-slim bezel design adds a sleek look to your ThinkPad X395.
  • Tested for battle, built for life
    Like all ThinkPads laptops, the X395 is tested against 12 military-grade requirements and more than 200 quality checks to ensure they run in extreme conditions. From the Arctic wilderness to desert dust storms, from zero gravity to spills and drops, you can trust this laptop to handle whatever life throws your way.
  • Battery life that keeps up with you
    When you're on the go, you can't be worried about finding electrical outlets. That's why the ThinkPad X395 delivers up to 14.5 hours of battery life. And if you're running low, Rapid Charge technology provides 80% capacity in just an hour. So with a 60-minute layover, you can easily boost your battery up to more than 11.5 hours.
  • A laptop that's well connected
    Whether you're on the go or working at your desk, the X395 keeps you online with the optional LTE-A card. This WWAN technology lets your laptop function like a smartphone-where there's cellular service you can always jump online, even if there's no WiFi available. And you can trust that your connection is secure.
Lenovo ThinkPad X395 - 13.3" - AMD Ryzen 5 Pro 3500U - 16 GB RAM - 256 GB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
AMD Ryzen 5 Pro 3500U / 2.1 GHz (3.7 GHz) / 4 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
256 GB SSD - TCG Opal Encryption 2, NVMe
Display
13.3" LED backlight 1920 x 1080 / Full HD
Graphics
AMD Radeon Vega 8
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac, Bluetooth 5.0
Up to 14.5 hours
Dockable
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
31.19 cm x 21.72 cm x 1.69 cm
1.28 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Max Turbo Speed
3.7 GHz
Number of Cores
Quad-Core
Cache
L3 - 4 MB
64-bit Computing
Integrated memory controller
RAM
16 GB (provided memory is soldered)
DDR4 SDRAM
Speed
2400 MHz
Rated Speed
2666 MHz
Storage
Main Storage
256 GB SSD M.2 2280 PCIe - TCG Opal Encryption 2, NVM Express (NVMe)
Display
13.3" - IPS
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
72%
Anti-glare, 170° viewing angle
Audio & Video
Graphics Processor
AMD Radeon Vega 8
Camera
Yes - 720p
Camera Features
IR camera, ThinkShutter camera privacy
Sound
Stereo speakers, dual array microphone
Codec
Realtek ALC3287
High Definition Audio, Dolby Audio Premium
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 9260
Gigabit Ethernet via optional Ethernet (RJ-45) adapter
DASH
Lithium Ion
48 Wh
Run Time
Up to 14.5 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 Gen 2 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack , HDMI , Lenovo Ethernet extension connector , Dock
Memory Card Reader
Yes (microSD)
Case Material
Glass-fibre, magnesium-aluminum alloy, polyphenylene sulfide
Dockable
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
USB-C power adapter
RoHS
Localization
TopSeller
1.28 kg
Sustainability Information
ENERGY STAR Certified
Essential Accessories (5)
Get more from your purchase from one of our essential accessories
F939 Lenovo 45W Standard AC Adapter (USB Type-C) Power Adapter In Stock £26.01
F939 Lenovo 65W Standard AC Adapter USB-C In Stock £29.56
F939 Lenovo USB-C 65W AC Adapter AC 100-240 V 65Watt for ThinkPad A275 In Stock £29.56
F939 Lenovo ThinkPad Hybrid USB-C with USB-A Dock - Do In Stock £194.89
F939 Kensington Security Cable Lock In Stock £23.65
Other bundles (13)
F939 Lenovo ThinkPad USB 3.0 Secure HDD-500GB In Stock £143.11
F939 Lenovo HDMI to VGA Monitor Adapter In Stock £23.20
F939 Lenovo USB3.0 To VGA/HDMI Adapter In Stock £63.85
F939 Lenovo 2m HDMI Cable In Stock £17.02
F939 Lenovo Professional Wireless Keyboard In Stock £54.36
F939 Lenovo ThinkPad Ethernet Extension Adapter Gen 2 In Stock £25.51
F939 Lenovo ThinkPad USB3.0 to Ethernet Adapter In Stock £16.07
F939 Lenovo Essential Wired Keyboard and Mouse Combo - UK English In Stock £25.39
F939 Lenovo ThinkVision M14 14" 1920x1080 6ms USB-C IPS LED Monitor In Stock £258.14
F939 Lenovo ThinkVision T24d 24" 1920x1080 VGA HDMI DisplayPort IPS LED Monitor In Stock £202.02
F939 Lenovo ThinkVision T27p-10 27" 3840x2160 HDMI DisplayPort USB-C IPS LED Monitor In Stock £454.54
F939 Lenovo ThinkVision P27h-20 27" 2560x1440 6ms HDMI DisplayPort IPS LED Monitor In Stock £336.70
F939 Lenovo ThinkVision T27q-20 27" 2560x1440 4ms HDMI DisplayPort IPS LED Monitor In Stock £321.24
