Lenovo ThinkPad X1 Extreme Intel Core i7-9750H 32GB 1TB SSD 15.6" Windows 10 Professional 64-bit
Quicklinx: FDH1WS00 Mfr#: 20QV00BRUK
  • Core i7
  • IEEE 802.11n
Creators appreciate the lightweight portability and stunning graphics performance from the ThinkPad X1 Extreme's NVIDIA GeForce GTX 1650 GPU. IT admins love the ThinkPad name and all that engenders - robust security and privacy features, trusted reliability, and craftsmanship renowned throughout the world. Global service options keep you protected, while built-in features like Glance eye-tracking and rapid-charging technology boost productivity levels. With a powerful processor and fast graphics, the ThinkPad X1 Extreme delivers accelerated performance for any job. It's plug-and-play ready for the VR/AR headsets. Whether you're creating content, gaming, traveling the world from your armchair, or streaming videos, you can do it all without lag time.
  • Something for everyone, IT admins and creators alike
  • Create multimedia or kick back and enjoy
  • An office assistant you can take anywhere
    With Cortana Premium, you can speak commands to your ThinkPad X1 Extreme from across the room. The integrated 360-degree far-field microphones ensure your voice carries its weight - up to 3 meters/10 feet away. The enhanced microphones mean you'll have superior VOIP performance. You can wake your device with a simple phrase. Quickly and easily find files and calendar events, even put your system into standby mode to improve battery performance. So go ahead and speak your mind - and boost your productivity at the same time.
  • Long battery life
    The ThinkPad X1 Extreme delivers hours of outstanding experience. A 60-minute lunch break or a layover can easily boost your battery for a long time. What more could you need for life on the go?
  • Stay connected
    Move data between the ThinkPad X1 Extreme and your other devices quickly with USB-C Thunderbolt 3 technology, which simultaneously supports high-resolution displays and high-performance data devices.
  • Supports up to 4 monitors
    The ThinkPad X1 Extreme supports up to four independent monitors - making working with complex computations, day trading, or analyzing big data a cinch.
Lenovo ThinkPad X1 Extreme (2nd Gen) - 15.6" - Intel Core i7 - 9750H - 32 GB RAM - 1 TB SSD - UK
Notebook
Operating System
Win 10 Pro 64-bit - English
Intel Core i7 (9th Gen) - 9750H / 2.6 GHz, up to 4.5 GHz / 12 MB Cache
32 GB DDR4 (2 x 16 GB)
Storage
1 TB SSD - TCG Opal Encryption 2, NVMe
Display
15.6" LED backlight 3840 x 2160 / Ultra HD 4K
Graphics
NVIDIA GeForce GTX 1650 / Intel UHD Graphics 630
Video Memory
4 GB GDDR5 SDRAM
Input Device
TrackPoint, UltraNav
Keyboard
Keyboard Backlight
Integrated Webcam
802.11a/b/g/n/ac/ax, Bluetooth 5.1, Gigabit Ethernet
Up to 14 hours
Security
Trusted Platform Module (TPM 2.0) Security Chip, fingerprint reader, smart card reader
Black weave
36.18 cm x 24.57 cm x 1.84 cm
1.7 kg
Manufacturer Selling Program
Lenovo TopSeller
Environmental Standards
ENERGY STAR Qualified
0.546 W/kg (body) , 0.546 W/kg (limb)
Limited warranty - 3 years - pick-up and return , Limited warranty - battery - 1 year
Bundled Services
3 Years Lenovo Premier Support
Notebook
Operating System
Windows 10 Pro 64-bit Edition - English
Processor / Chipset
CPU
Intel Core i7 (9th Gen) 9750H / 2.6 GHz
Max Turbo Speed
4.5 GHz
Number of Cores
6-core
Cache
12 MB
64-bit Computing
Chipset
Mobile Intel CM246
Integrated memory controller
RAM
32 GB (2 x 16 GB)
Max RAM Supported
64 GB
DDR4 SDRAM
Speed
2666 MHz
Rated Speed
1333 MHz
SO-DIMM 260-pin
Slots Qty
2
Empty Slots
0
Storage
Main Storage
1 TB SSD M.2 2280 PCIe 3.0 x4 - TCG Opal Encryption 2, NVM Express (NVMe)
Display
15.6" - IPS
LCD Backlight Technology
LED backlight
Resolution
3840 x 2160 (Ultra HD 4K)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
500 cd/m²
Colour Gamut
100% Adobe RGB
Anti-glare, 170° viewing angle, Dolby Vision, HDR400
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
4 GB GDDR5 SDRAM
Video System Features
Max-Q design
Camera
Yes - 720p
Camera Features
IR camera, ThinkShutter camera privacy
Sound
Stereo speakers, dual array microphone
Codec
Conexant CX11880
High Definition Audio, Dolby Audio Premium, Dolby Atmos
Input
Keyboard, TrackPoint, UltraNav
Keyboard Backlight
Keyboard Layout
Spill-resistant, multi-touch touchpad, buttonless touchpad
Communications
Wireless
Wireless Controller
Intel Wi-Fi 6 AX 200
Network Interface
Gigabit Ethernet
Ethernet Controller
Intel I219-V
Lithium Ion
80 Wh
Run Time
Up to 14 hours
AC Adapter
Input
Output
135 Watt
Connections & Expansion
Interfaces Details
USB 3.1 Gen 1 (Always On) , USB 3.1 Gen 1 , 2 x USB-C 3.1 Gen 2 (supports Thunderbolt 3, DisplayPort Alt Mode) (Power Delivery) , HDMI , Lenovo Ethernet extension connector , Headphone/microphone combo jack , LAN (on supplied cable)
Memory Card Reader
Yes (SD Card, SDHC Card, SDXC Card, SDXC UHS-II Card)
Black weave
Case Material
Aluminum, glass-fibre reinforced plastic, carbon fibre reinforced plastic
Security
Administrator password, hard drive password, power-on password, RapidCharge, MIL-STD-810G tested
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter, ThinkPad Ethernet Extension cable
RoHS
Localization
Lenovo TopSeller
1.7 kg
Sustainability Information
ENERGY STAR Certified
Bundled Services
