Lenovo ThinkPad Workstation Dock Port Replicator 230 Watt
Quicklinx: C87KWS00 Mfr#: 40A50230UK
£229.41 ex VAT
£275.29 inc VAT
The completely redesigned and supercharged ThinkPad Workstation dock with included ThinkPad 230 W AC adapter enhances your work capability with multiple connectivity options. As the ultimate multi-port docking solution, the ThinkPad Workstation dock includes a range of video outputs, including HDMI 1.4, and DP 1.2 to support multiple external monitors delivering outstanding driver-free video quality. With an enlarged support base, the Workstation dock can accommodate both P50 and P70 mobile workstation notebooks. It comes with 6x USB 3.0 ports, one of which supports always-on USB charging to charge your tablet or mobile device without even needing to connect your ThinkPad notebook. The other USB 3.0 ports are ideal for connecting memory sticks, external storage devices and other productivity accessories as needed. Additional ports on the ThinkPad Workstation dock include a 10/1000 Gigabit Ethernet connection, 2x display 1.2 ports, 1x DVI-D port, 1x HDMI 1.4 port, 1x stereo/mic combo audio port and 1x VGA port. The dock comes with a 230 W AC adapter to power and charge your mobile workstation notebook.
Lenovo ThinkPad Workstation Dock - port replicator - VGA, DVI, HDMI, 2 x DP
Port replicator
Video Interfaces
40.22 cm x 16.54 cm x 5.56 cm
980 g
United Kingdom
Power adapter 230 Watt AC 120/230 V (50/60 Hz)
1-year warranty
ThinkPad P50 20EN, 20EQ; P51; P70 20ER, 20ES; P71
Port replicator
40.22 cm
16.54 cm
5.56 cm
980 g
United Kingdom
6 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x audio / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x audio / video - HDMI - 19 pin HDMI Type A , 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 1 x audio - headphones/microphone - mini-phone 3.5 mm 4-pole , 1 x docking / port replicator
2 x security keys
Security lock slot (cable lock sold separately), 1 USB 3.0 (Always On)
UL, VCCI, BSMI, GOST, NOM, CB, DOC, FCC, KCC, UkrSEPRO, AS/NZS
Power adapter
Power Provided
230 Watt
Limited warranty - 1 year
5 °C
43 °C
Lenovo ThinkPad P50 20EN, 20EQ , Lenovo ThinkPad P51 , Lenovo ThinkPad P70 20ER, 20ES , Lenovo ThinkPad P71
Brand: Lenovo
