Lenovo ThinkPad USB3.0 to Ethernet Adapter
Quicklinx: F2B6WS00 Mfr#: 4X90S91830
More than 50 In Stock
£16.07 ex VAT
£19.28 inc VAT
The ThinkPad USB 3.0 Ethernet adapter enables Ethernet on systems which do not have Ethernet RJ-45 connector through USB port on the system. The ThinkPad USB 3.0 Ethernet adapter not only provides high speed Gigabit Ethernet solution via USB 3.0 port, but also enables boot over the LAN on selected ThinkPad systems. Connect it with your ultrabook or tablet to your corporate VPN at the office or go online in a hotel suite. The adapter's small form factor allows a convenient fit into any computer case or bag to travel, so you can easily take it with you anywhere.
Lenovo ThinkPad USB 3.0 Ethernet adapter - network adapter - USB 3.0 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
5 cm 3 cm
Length
18 cm
Australia, New Zealand
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
PoE, QoS
1 x 1000Base-T - RJ-45
1 x USB cable (integrated)
VCCI, C-Tick, BSMI, CB, FCC, ACA, ICES, KC, EAC
5 cm
3 cm
Length
18 cm
70 °C
