The ThinkPad USB 3.0 Ethernet adapter enables Ethernet on systems which do not have Ethernet RJ-45 connector through USB port on the system. The ThinkPad USB 3.0 Ethernet adapter not only provides high speed Gigabit Ethernet solution via USB 3.0 port, but also enables boot over the LAN on selected ThinkPad systems. Connect it with your ultrabook or tablet to your corporate VPN at the office or go online in a hotel suite. The adapter's small form factor allows a convenient fit into any computer case or bag to travel, so you can easily take it with you anywhere.
- Lenovo ThinkPad USB 3.0 Ethernet adapter - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- 5 cm 3 cm
- Cable Length
- 18 cm
- Localisation
- Australia, New Zealand
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- IEEE 802.3, IEEE 802.3u, IEEE 802.3x, IEEE 802.3az
- Designed For
- ThinkPad T16 Gen 4 21QN; ThinkSmart Hub 11H1
- Network adapter
- Form Factor
- External
- Localisation
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- PoE, QoS
- 1 x 1000Base-T - RJ-45
- Cables Included
- 1 x USB cable (integrated)
- VCCI, C-Tick, BSMI, CB, FCC, ACA, ICES, KC, EAC
- 5 cm
- 3 cm
- Cable Length
- 18 cm
- 0 °C
- 70 °C
- Designed For
- Lenovo ThinkPad T16 Gen 4 21QN , Lenovo ThinkSmart Hub 11H1
